Question about Cell Phones
I can't power on my phone
I enter in eng.menu and press ''hight speed sim card''.Now phone is dead. Please help me!? Phone is dual sim H626
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
You can change GSM frequencies to 900/1800 by entering the enginnering model.
Following the below steps:
enter menu and press 048263* quickly,
then you will enter the secret engineering menu under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650,
press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.
press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.
You will receive an extra 50 msgs memory space.Switch phone off and back on.
Hope this helps.
Thanks for using fixya .
Jan 26, 2011 | Motorola Mobility V360 Cellular Phone
My motorola v360 unlock code and security code has been changed and now i cont entre my phone please help?
hello,
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 20, 2011 | Motorola Mobility V360 Cellular Phone
I NEED THE 16 DIGIT CODE TO UNLOCK MY LG CU920
How to enter Unlocking Codes for LG Phones for Various U.S
Below are instructions that work for most network providers.
1:Insert not-allowed SIM card
2:Power on the handset- phone will display “phone restricted”
3:Select “Cancel” - phone will display “phone restriction code”
4:Enter the SIM unlock code
5:Select “OK” - the handset is now successfully unlocked
How to Unlock LG KG245 (Vodafone Australia)
1:Insert a Vodafone Australia working SIM card.
2:Ensure the phone is charged and then switch the phone on.
3:Optional Step: If the SIM card has a PIN, enter your PIN number
4:Wait for the phone to power up then enter 2945#*7101#
5:Select Menu , then go to Settings > Security > SIM Lock > Network
6:Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7:The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
1:With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2:Go to: Settings>Security>SimLock>Network
3:Select deactivate. Enter the unlock code,
1:Power on the handset - phone will display “phone restricted”
2:Select “Cancel” - phone will display “phone restriction code”
3:Enter the SIM Unlock code
4:Select “OK” - the handset is now successfully unlocked
1:With allowed sim card in the start menu type: 2945#*3311#.
2:Handset shows saved, then return to startup screen
3:Press Menu key, choose Settings > Security > Sim Lock> Network eactivate, handset will now show ‘Enter NCK’
4:Enter your unlock code and OK.
1:Switch ON your phone with a not allowed SIM card.
2:Compose: 277634#*#.
3:Go to menu “SIM Lock”.
4:Enter the unlock code, which you can buy any online store .
1:With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2:Select ‘Sim Unlock’ menu #
3:Enter NCK code then validate
1:With a not allowed sim card enter Pin code then validate, type: 277634#*#
2:Shows test menu
3:Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4:Handset shows ‘Enter NCK’
5:Enter code, then hit OK.
1:To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2:Enter the code
1:Insert non-Cingular SIM card.
2:Power on the handset. Phone will display “Invalid SmartChip”
3IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4:In Idle screen, enter 159753#*#. Phone will display “Enter NCK, Remaining 5
5:Enter the 8 digit SIM unlock code, which you can buy any Oline phones.
6:Select “OK”. The handset is now successfully unlocked
Then compose:
Go to “Menu” and then to “Settings”
Then select “Security”
To finish select “Network Provider” and select “Deactivate”
Enter the unlock code, which you can buy Online store unlock-cell-phones.
How to Enter Unlock Codes on all other LG U400 Shine (2 codes needed):
1:Insert the network SIM in the handset which works with the phone (from the locked carrier).
2:Enter 2945#*88110#.
3:The phone will then prompt ‘Unlock sim’. Press OK.
4:The phone will then prompt ‘Network Unlock’. Press OK.
5:The phone will then prompt- ‘Input Network Control Key’. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
6:It should give you the message: Success.
7:Come back to the main screen and Enter 2945#*88110#.
8:The phone will then prompt unlock sim. Press OK.
9:The phone will then prompt Network Unlock/ Lock but if you scroll down
10 :you will see a message Enter SP Lock. Enter SP Code.
Then press OK.
How to Enter Unlock Codes on all other LG KE970 Shine:
1:Switch ON your phone with an allowed SIM card
2:Then compose: 2945#*9701#
3:Press CALL.
4:It should you ask you for the code.
How to Enter Unlock Codes on all other LG TU720 Shine:
1:Put in a non-allowed SIM, phone says invalid SIM card
2:Now enter *#865625# then enter your 16 digits code.
How to Unlock LG KG800 Chocolate Without a Code (not reliable):
1:Insert SIM from the network that it is locked to.
2:Turn on phone.
3:On home Screen, slide up phone.
4:Type 2945#*#
5:ENG. Mode menu should appear.
6:Go Down to Factory Reset. Select it. May take a few minutes to reset!
7:This will reset the phone back to before the phone was locked to a network.
8:The phone will automatically restart (the network logo at start up will not change).
9:Now insert any SIM card and the phone should turn on normally
10:The phone is now unlocked and you can customize the setting as you like
How to Unlock LG Vu CU920
June 11th, 2008 by Eric
On the AT&T Network, to unlock the LG Vu or CU920, it’s pretty simple:
Enter *#865625# then the 16 digit unlock code*
*The 16 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
Dec 05, 2009 | LG Vu CU920 Cellular Phone
How to convert flight mode to normal mode
with out sim *#3646633#
you wil get eng menu
option 5 misc
option 6 assert testing
now menu will open
u select dual mode it will work confirm otherwise you format your phone
Dec 17, 2008 | Handmark Software MobileLists (950142) for...
Sigmatel S90 dead
my phone has dead when i activate speed sim so i press the power button the keypad light blink i have tried more time but his not ON
Oct 02, 2008 | Samsung SCH-U470 Juke Cellular Phone
Unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Jan 04, 2008 | Lands Phones
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
