Question about Sirius Satellite Radio Receiver
Radio plays upon startup but withing minutes message says searching for signal then antenna not found. replace antenna?
    President:
  • 1,114 Answers
No, it's the Sirius Tuner. If it's 2 or so years old, there's a bad ground on the antenna port pc board. If your tuner is roughly 6"x6"x1" it's the one. The new tuners will not have this issue and are considerably better built. (DEI) is the manufacturer of the new unit. If you don't mind rebuilt, you can save 40 or 50 on a repaired tuner. The repaired tuners are very reliable since they upgraded the board with one that's durable. Hope this helps
Posted on Dec 10, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Bad ground
Posted on Dec 11, 2009
I have the problem with my receiver. I have the Sportster 4. Is there anywhere I can send it off to get it fixed? I would rather get my old radio fixed, than buy a new one. Hope someone can help. Thanks
Posted on Jan 15, 2010
The dispaley states "aquiring antenna" but never finds it,can this be fixed?
Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
Jun 01, 2012 | Sirius Satellite Radio Sirius Sportster...
What is wrong with a satellite reciever when all I am getting is aquiring signal displayed
This indicates that the antenna is not gathering enough of the signal to be played. This can be caused by an obstruction between the antenna and the satellite in the sky ie: tall buildings, heavy tree cover, covered garage, etc. It can also indicate a problem with the antenna itself, the cable between the antenna and the radio, the connector on the end of the cable or in the radio or, a problem with the antenna circuit inside the radio.
Since there's little you can do about the last item in the list, check the other parts of the antenna for damage. A pinched or crushed cable will short out the antenna signal - and the voltage sent to it by the radio. If allowed to persist for very long, damage to the radio could result. Look for breaks in the outer jacket of the cable - water entering the cable will cause corrosion and will degrade the signal, too. If you find a problem with any part of the antenna system, about the only thing you can do is replace the antenna completely. You can get a replacement online for as little as $9 and change.
Before installing, try connecting the antenna to the radio with the antenna exposed to ta clear view of the sky in a location that you were able to receive a signal before. If it works, you're done. If it doesn't - the problem is internal to the radio and will need to be repaired - or replaced.
I hope this was helpful - if it was - please rate it "4 thumbs up" Thanks!
Aug 02, 2011 | Sirius Radio Receiver
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
I have a scanner and want to use another source for the same antenna is this possible
Antenna splitters are available to let you use more than one receiver on a single antenna with minimal signal loss. Grove Enterprises (http://grove-ent.com/) is one source, and a Google search should bring up others. Unless you're tapping into a fantastic outdoor antenna though, you might want to consider a low-cost indoor antenna such as this one that I found on eBay:
http://cgi.ebay.com/SNOOP-SCANNER-ANTENNA-FITS-UNIDEN-BEARCAT-police-radio-/150442224106?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item23070e29ea
Bill B
May 16, 2010 | Radio Communications
Can an on-off switch in car antenna help FM transmitter sound ?
  • they are dependent upon the antenna. best thing to do if u want a to spent the time and money to do that would be to install a new stereo witha AUX plugin instead of your FM transmitter
Dec 02, 2009 | Car Audio & Video
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
"no antenna" message
It could be the antenna wire is shorted especially if its the lower gauge wire.
Antenna's are fairly inexpensive to replace you could test it by setting a different antenna on the dashboard and see if the previous antenna is bad.
May 15, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
Sep 09, 2007 | Rio SIRIUS Starmate Replay Receiver
Sirius Satellite Radio Receiver Logo
568 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
