Capicator Not sure if Capicator for goodman ck49-1b is correct, System not running but has power from Disconnect. Currently had two differant Capicators in the unit a 440 volt oval cap with two post and a 370 oval cap with two post Schemtics show a round Cap with fan, herm and Compressor post I guess this is most likely the problem but not certain if it requires a 370 volt cap or the 440 round cap?
  • 447 Answers
Sounds like someone has replaced the origional split cap (fan,herm,common..not compressor) with two seperate units. The voltage doesnt really matter its the MFD rating that will need to be the same. The larger #mfd capacitor will be the compressor's and the smaller the fan motors' capacitor. Since it does have two seperate caps than the liklihood that they are your problem is slim i would look elsewhere.
Posted on Jan 20, 2008
Fan not spinning on Amana RCB30B2A unit. Compressor is running though
It's the run capacitor for your fan. You'll need to pull it out and replace it. Look on Youtube about how to replace a condensing fan run capacitor. Make sure you get the same voltage and microfarad rated capacitor. Make sure you also disconnect the power to the unit. You can get the part at any HVAC parts house or Grainger. Should cost around $15
Jan 12, 2018 | Amana Heating & Cooling
How to fix a capicator for a goodman cple-42-18 air unit
The capacitor must be replaced if not working. They are not made to be repaired.
Jun 03, 2012 | Goodman Heating & Cooling
Unit will not run. Changed the capicator and it still does not work.
what doesn't work? the condenser the fan the compressor ? need more details
Aug 12, 2011 | Goodman CKL42AR42 Air Conditioner
I purchased a new Goodman AC/Heat inside and out side units, am getting ready to run the wiring to the sub panel, Not sure what wire to use from the main braker box to the sub box have found different...
http://www.encorewire.com/docs/amp%20voltage.pdf is a diagram of what size wire and type you need for different amperage. As you can see the 10/3 recommendation is good for a maximum of 30 amps in copper and 25 in aluminum.
I haven't found the CKL36AR36 installation guide, so I don't don't know which circuit breaker size you need to install. But it should be listed in your installation guide that you got with your unit. Make sure that you have the correct disconnect within 6 feet of the unit to meet code.
Jul 12, 2011 | Goodman CKL36AR36 Air Conditioner
My outdoor AC unit is not coming on. Air is blowing out of my vents inside but the snowflake symbol on my thermostat is blinking and the air isn't cold. The fan on the unit isn't even running. Any...
check power to outside unit, check if it has a fused disconnect, if you have power and no blown fuses it could be a blown capicator that starts the fan and compressor...............
May 09, 2011 | Heating & Cooling
Goodman cph30-1fb a/c stopped working
Try This,
If The A/C Unit Compressor Is Humming, Not Running
And/Or
The A/C Unit Fan Is Humming, Not Running.
Replace The Dual Capicator Inside The Unit Outside,
READ THIS ENTIRE DOCUMENT BEFORE PROCEEDING ANY FURTHER!!!!!
Remove Access Door Panel
You Will See The Compressor 24VAC Coil/Contactor, This Is For The Compressor,
What Turn's It On Is The 24VAC From Your Thermostat, These's Are OPEN Contact
Relay's, They Should Be Replaced Every 5yrs, As Well As The Dual Capacitor.
Suspecting Your Dual Capactior Is Bad,
BEFORE ENTERING Access Panel, Kill The Breaker Feeding Your
Outside A/C Unit, and/or RAISE Thermostat So A/C Unit Will Not Come On, Then,There Might Be A Elec Box Located Next To The Unit, Open The Cover, Pull The "T" Handle, Remove From Box, This Removes All Electrical Power From Outside Unit.
NOW WAIT 15 Minutes, [Let Capactior Power Drained/Down/out.]
NOW IT IS SAFE TO Preform The Next Part.
Remove The Access panel For The Electrical Compartment,
You Will See a Metal Looking Cylinder, Not Round, But Oval Shape, Will Have Wire's
Going To Top Of It, Remove The Clamp Securing This To The A/C Unit Frame.
DONOT DISCONNECT ANY WIres @ This Time.
Move The Capacitor So You Can See The TOP Of It,
You Will See "HERM" on One Side
COM in the Middle
FAN On The Other Side.
Write Down The Color Wire[s] Going To Each Connection.
Now Remove The Wire's From The Capacitor,
The Capacitor Has printed/Label On It
This Show's Voltage and MFD Ratings.
Take This To Your Local Heating & Air Supply Company, Ask For A Direct
Replacement, Based On The Data Listed On It.
You Might Get One Back Looking Different, But The Voltage/MFD's Will Be The Same.
Installed The Replacement Capacitor, W/ Correct Colored Wires.
Remount Capactior On A/C Unit, Make Sure It Cannot Move, Fallout.
Re-Install Access Cover
Turn ALL Power back Onto Unit
Set Thermostat So Unit Should Come On, Should Be Working.
If You Can, Replace 24VAC Compressor Contact/Relay,
Like The Old Cars, Point's Are Pitted After Long Use, Causing Problem[s].
If The Unit Is Working, Here's What Happened:
The Capacitor Got Weak or Failed,
"HERM" supplies VAC To START The A/C Compressor
"FAN" Supplies Voltage AC To Start The A/C Unit's Fan
"COM" Is The Common Electrical Wire Circuit Between The Two [Herm &Fan]
The Capacitor Is Like A Starting Circuit, A Good Capacitor Will Start The
HERM [Compressor] & FAN FAST, a Weak One Will Cause A DELAY
Before Acheiving TOP RPM/Speed, This Cost More on The Electric Bill &
Makes The Compressor Motor & Fan Motor Work Harder, Causing
Early Failure's Of The Motor[s].
You Should Replace Both The 24Vac Relay Contactor & Capacitor
Every 5Yrs, Whether The Unit Is Working Or Not.
These's Are The HEART Of The System, They Get Weak, Will Hurt Rest
Of The Major Parts Of Your A/C System.
Hope This Help's
Note: I'am EPA Certified Universal Section 608 Since 1994,
I Have A full Time Job, A/C Work Is Sideline Work,
I'am a Industrical Electrician/Instrumentation Engr Tech, For Starter's,
If You Get Advice from Someone Else, And It's Different, They Have
MisInformed You or They Don't Know What They Are Talking About.
Later Friend, God Bless All!
Retired USMC and Other's
If You Need More On The Spot Advice, Call Me [770] 606-8871 anytime,
I'am Home This Weekend. [Jeff]
For Other's , My # Is Blocked, ect, When You Call I Will Know You,
So Make Sure Before You Call, Who Is It I'am Really Calling.
Jul 10, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Jul 03, 2009 | Goodman CLJ36AR42 Air Conditioner
Connecting electronic air filter to furnace fan
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
Hope this helps,
Matt
Dec 31, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
397 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
