Question about Nintendo DS Console
Power button slides but wont turn it on. it is like it is disconnected
  • 48 Answers
You might need to get a new d.s system because you might have broke it .
Posted on Dec 11, 2009
Wont turn on pressed the reset when it froze and now it wont go back on
Press the Power ON/OFF slide button.
To power ON, push Slide UP & hold for 5 sec's
To power OFF, push Slide UP & hold for 5 sec's
If no go,
Use the Stylus and push into Reset hole, at bottom of device.
(not on back side, but at the bottom, where there is a single hole.
Press and hold for a second or two, or until it turns off/on.
Pushing Slide DOWN, put's it HOLD mode (make sure the slide
switch is Not in the Down position) is probably in Hold mode?
I've had this problem before and finally realized that I was putting it in
the hold mode every time, by pushing the Slide Power button, down.
Instead of UP.
May 24, 2011 | Mach Speed T3000 MP3 Player
Wont turn on or connect to computer
Try sliding the power button all the way down to hold, then in one slide, slide it all the way up to power on. Hold it there for several seconds. The Fuse should power up after that.
Jan 07, 2011 | SanDisk Sansa Fuse MP3 Player
IPhone wont turn off
Unlock the screen.
Press the button on the top of the phone and hold it down.
In approximately 5 seconds a "slide to power off" message should appear.
Slide the slider and power off the phone.
If this does not work take it to an Apple or AT&T store.
If this helps please vote for my solution.
Jun 24, 2010 | Apple iPhone 3G Black Smartphone
I phone wont open
Try turning the phone off. When the screen appears and says "slide to turn off" or cancel, press cancel. If that works then do it again but slide to turn off. If you cant slide, then you need a new digitizer. There are some other things to try like a hard reset, where you hold the power button and the home button at the same time when it's plugged into the computer, but I've never been able to get that to fix a phone where the slide capability stopped working.
www.usedcellphoneshop.com
May 08, 2010 | Apple iPhone Smartphone
My mp3 wont turn on unless its connected to charger, i charged it all night last night and this morning i took it to school and it wouldnt turn on. it only turns on when i plug it into charger right when i...
Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Mar 17, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Can't turn on my coby mp610 after charging it to full power It played one song, then pooped out on me ... just turned off. Can't turn it back on and when I hook up usb to computer it doesn't even light...
Try sliding the power button down and then pushing it in as well. My daughter's would work if we left it on after disconnecting from the computer but would not turn back on if we turned it off.
Finally, I tried sliding the switch down and pushing it in and it worked. I am worried how long this will work however and it does not inspire confidence in quality.
Sep 19, 2009 | Coby MP-C7085 MP3 Player
Droppd iphone now i cant unlock it. slide wont move. i can turn
Try holding the top power button until unit turns off. Then Hold power button until apple logo appears. It should reboot.
Aug 30, 2009 | Apple iPhone Smartphone
Reseat the hard drive
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Feb 03, 2009 | Dell Inspiron 1525 Notebook
My nuvi 780 suddenly won't power on. Used it this morning and then a short while later it's broken!
Solution A:
1. Disconnect from power source (automobile cradle and/or usb cable)
2. Slide the power button right into the lock position.
3. Slide the power button to the left and hold it for 10 seconds.
4. Your unit should have powered on after you released the power button
Solution B:
3. Apply light pressure anywhere on the touch screen with your finger.
This worked for me... hope it works for you. - Happy Holidays!
Dec 04, 2008 | GPS
Nintendo DS Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
