Question about Dishwashers
6 yr old kenmore dishwasher does not clean dishes well. there are no restrictions on both power washer arms, both spin well, but I'm not getting hot water, only warm. any suggestions? John
    Champion:
  • 246 Answers
Check the drain, filter, and make sure there is no food stuck in there. Also, check out www.applianceart.com for dishwasher door options.
Posted on Dec 11, 2009
Sears dishwasher not cleaning
You may have a bad pump, or the pump intake (inside the bottom tray, under the dish racks) may be clogged with crud from years of dirty dishes.
Jul 31, 2014 | Kenmore km 665.15765692 3376066 Det Latch,...
Dishes are not clean after cycle, not sure what to do , opened in middle of cycle and steam comes out so water appears to getting hot, not sure if rotors sprayers are turning how can I tell, washer is...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 11, 2011 | Frigidaire Dishwashers
10 yr old Kenmore dishwasher was leaking, cycling ok but dishes are not coming out clean. Took about bottom spray unit, found a split plastic round ring about 1.5" dia. Could this be the problem or what...
The ring fits just under the spray arm and the split is normal. When you tore the spray assembly apart, did you clean the screens at the bottom (if white hard-water deposit, soak in 50:50 hot water and white vinegar)? Make sure none of the ports in the deck are plugged with food deposits. Check both spray arms for plugged spray holes or split seams. The upper arm moves from water pressure alone--no motor. Make sure it spins freely by hand. We had to try different detergents to get away from a gritty deposit on glassware. Did you fix the leaking problem? Inspect the gasket seal around the door for damage or hardness and check the latch for holding the door closed firmly. Hope some of this helps!
Oct 17, 2010 | Kenmore Dishwashers
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Dishes not getting clean
Are dishes too greasy!
Check incoming water for free flow
Add correct quantity of soap as per manual. Use dish washer friendly soap. Fill rinse aid liquid in the dispenser meant for it.
Select a different cycle programe and give a try.
May 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Elite Dishwasher not cleaning well
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
45jdgyhj
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Middle spray arm not spraying
unlikely that 2 dishwashers would have the same fault but is of course possible
could it be to do with how you are loading? quite common is for a knife or similiar to stick down thro the rack and jam the arm
Nov 19, 2008 | Dishwashers
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
