Question about Alpine Air XL-15 Air Purifier
Living air xl 15 One of the two glass plates inside has broken along the edge of the mesh. "Adhesive" material that appears to hold the mesh in place is blackened as though burned. Fan will come on but no "sparking' no matter how high I turn up the power. How do I replace the glass and how do I know if that will fix the problem?
  • 368 Answers
Broken discharge plates have to be replaced, otherwise the high-voltage shorts-out through the break. The glue being burned is an additional clue.
The fan is a separate circuit/function.
Replace the glass plates (purchase from EcoQuest Intl. or from a EQI dealer near you, expect to pay ~$20-30/plate depending on model and shipping costs. I also sell them as I am an EcoQuest™ dealer, though the shipping charges may make me less economical than someone local to you. If you want my contact info, please respond with a "FixYa" rating - thanks in-advance.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Dec 29, 2009
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
How often does the manual suggest changing the glass plates?
Clean the filter and dust out the inside from time to time. If the plates are slightly chipped, it mon't matter. Mine has been in constant use for about 3 years. That's all I do and it works just fine.
Aug 05, 2009 | Alpine Air XL-15 Air Purifier
Have a Living Air XL15 > everything works motor, fan, BUT .....
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Apr 26, 2009 | Ecoquest Living Air Classic Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Dec 03, 2007 | Alpine Air XL-15 Air Purifier
Fan is not turning on
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Oct 26, 2007 | Ecoquest Living Air Classic Air Purifier
Alpine Air XL-15 Air Purifier Logo
126 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
