Question about Nintendo Super NES Console
Snes My super nintendo won't turn on.I'm pretty sure i have it all hooked up right,but the light doesn't even turn on.
  • 3 Answers
Well, with our super nintendo, the plug in wire was crappy, so you had to have the wire turned a certain way for it to work......we still have never fixed it
Posted on Jan 31, 2008
  • 20 Answers
It could be one of two things.
First and most likely is the AC Adapter is shot. It could have a broken wire in the plug or the AC Adapter itself could be bad. The quickest way to check for this is to take it to an electronics store like Radio Shack. They should be able to tell you if it is bad.
Second it could be the console itself. Look at the receptacle for the AC Adapter. There should be a small round plastic piece with a hole in the center of it that the plug fits around and in. These often break but you can usually get the console to turn on if you wiggle the plug around. It could also be an internal problem with the console. The only way to check for this is to make sure you have a good AC Adapter. If the light comes on the console is good. I have never seen a burned out light.
Either way the bad part would need to be replaced. Neither one is cost effective to fix and both are still readily available on various websites.
Posted on Jan 20, 2008
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
SNES model sns-101 won't work on my flat screen
Well it might be dirty then try cleaning the game packs out with qutips and rubbing alcohal. Or try using av cables instead of an rf switch
Jun 29, 2012 | Nintendo Super NES Console
When I hook up my SNES there is no picture - what do I do?
Well onlhy use the old consoles on CRT tv styles then.
Apr 08, 2012 | Nintendo Super NES Console
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
It wont turn on
I never had a SNES, But I had a Super Nintendo Box.
Contact nintendo,
If you were to call Nintendo,they can't do nothing about this. It's too old.
Mar 06, 2010 | Nintendo Super NES Console
Controller port or system and why...
open and clean the controller pad....or buy a new one....sometimes snes joypad goes crazy with dirty inside the buttons contacts, it gives the impression that is a defective console..but in most of the time..the snes joystick need a fix !!! Good Luck!!!
Sep 10, 2009 | Nintendo Super NES Console
Games are in black and white-no color
Make sure the cables are hooked up properly. Audio to the audio input and video into the video input of the tv.
If they are hooked up right and you still only get black and white pictures then the cable might be bad so get a new cable.
If you still have a problem even with a new cable then its something to do with the connector in the SNES or the main board itself.
May 21, 2009 | Nintendo Super NES Console
Snes screen jumps on certain tv
Okay, what I would try is hooking up the snes using the n64 cable. right next to the rf slot in the back of the super nintendo is a slot thats the same video output as the n64 you can plug in the rca cables from it and see if they work
Feb 27, 2009 | Nintendo Super NES Console
SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Jun 14, 2008 | Nintendo Super NES Console
Nintendo Super NES Console Logo
139 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
