Question about Apex Digital AVL2776 27 in. HD-Ready LCD Television
I turn it on and then cut off. i have to do this
I turn it on and then cut off. i have to do this 5 to 10 times before it stay on. Also it sides is fusses.
  • 557 Answers
Sounds like a bad cap or two. Capacitors that are weak will work after they heat up. In many cases the cap can have a visual sign of being bad the top will be bulged. That is not always the case and then they have to be checked with a meter.
Posted on Dec 10, 2009
I recently purchased a 20 gal/1.5 HP, model 921.166420. The reset button on the side of the motor, (thermal overload Protector?) cuts out repeatedly. The few times where the motor did run and the pr
Could be weak thermal cutout or actual problem with unit. Thermal cut out easy to check with amp meter. Connect meter as required to monitor draw as unit fills and make sure that it stays at or below usage stated. If amp draw stays below stated usage and thermal cuts out, replace the part. If amp draw goes over amount stated turn off compressor and listen for air leaks (usually check valve will leak back pressure to pump causing extra load on motor).
Nov 29, 2011 | Craftsman 150 PSI Air Compressor
Tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself.
this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I have seen this problem in the shop with this set. IN MY CASE it was shorted convergence chips. but it could also be any of the low voltage supplies 5,10 15,-15 lines
Oct 16, 2010 | Sony KP-53HS30 53" Rear Projection...
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Touchscreen wont cut off when car is turned off.
It is normal for the screen to stay on for a short period of time after you turn off the engine and leave the car. It should shut off after a minute or so.
Feb 13, 2009 | 2006 Land Rover Range Rover
Back light will not come back on.
if your on the back light settings, then press the down arrow three times. if your not, you can tilt it in a certain way so that you can kinda see what your doing
Feb 17, 2008 | Motorola Mobility TracFone® V170 Cellular...
Side by sise fridge
yes it varies for how long the unit should stay in defrost 30 Min's for every 8 hrs of compressor running time keeping in mind that the compressor don't cut on till the thermostat tells it to there also is a defrost thermostat that cuts the heater off when the coils reach a preset temperature
Jan 21, 2008 | Whirlpool GS6NBEXR Side by Side...
Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
thanks
Oct 15, 2007 | Mach Speed (S755) Motherboard
Apex Digital AVL2776 27 in. HD-Ready LCD Television Logo
102 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
