Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Samsung HLP5674W DLP television shuts off after a few minutes
I have a Samsung HLP5674W DLP television. After operating for a few minutes, the tv shuts off, and all three lights on the front panel flash.
After checking the flash code, I checked the sensor (trip switch) on the lamp cover. I made sure the switch was fully tripped but this made no difference.
I then bypassed the switch, completing the circuit and still no difference.
I don't know what to try next.
    Sergeant:
  • 381 Answers
Make sure the color wheel is ok. If it is, replace lamp and ballast.
Posted on Dec 13, 2009
SOURCE:
Samsung HLS-6167W shuts off every few minutes. I replaced the lamp 3x and recently the lamp ballast and #2 fan. Problem continues, so should I look at the power supply board or the color wheel?
if the sounds a high pitch squeal !! I had an ole tv that did that when u watched it , finally one day the dang power supply up and gave out !! so that must be what the noise was coming from all that time !!!
Dec 20, 2016 | Samsung Televison & Video
Tv timer shuts off
If the TV gets very hot it maybe shutting down on its own accord however there should be a way to navigate to the sleep menu through the buttons on the front of the set.
Feb 19, 2013 | Samsung Televison & Video
Keeps switching itself off and on???
Provided that your lamp is not reaching the end of its life, there have been some issues with the lamp door switch opening due to thermal expansion of the plastic. I would bypass the two wire switch altogether to eliminate this possibility, it won't affect the operation of the TV. If the set still shuts down, and there is no on screen display mentioning a fan failure, replace the lamp. Part number is listed on the lower left side of the TV with red label.
Bill W
integrityhomeworx.com
Mar 23, 2011 | Samsung HLP5674W 56" Rear Projection...
The top left speaker in my samsun HL-P5685W DLP TV has blown, I need to find the specification for the speaker in order to be able to order it
I have not been able to get a part number from my normal suppliers as it is not listed. I would suggest that you call Encompass parts directly at 866.779.7421. They should be able to provide you with the part number and cost.
Dan
Sep 29, 2010 | Samsung HLP5674W 56" Rear Projection...
Tv shuts off and on by itself dlp 5064 tv only seems to do it when the tv is on for a long period also when the power is on the standby/lamp is illuminated
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. I
Jul 26, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP
Yup definitely sounds like the ballast, if not then you have a problem in the power supply. Probably some bad capacitors. Call a local tv repair shop.
Nov 28, 2009 | Samsung DLP HL-P5663W 56" TV
My screen has white dots all over the screen..they started out with just a few but over time they seem to have spread. Any idea if this is fixable? The television is only 3 yrs old.
Usually, the white dots (they should look more like small squares) indicates that the DLP chip is failing and needs to be replaced. It's located on the DMD board and is very expensive to replace. If you have an extended warranty, call and get them out to check.
Jun 05, 2009 | Samsung HLP5674W 56" Rear Projection...
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
