Question about Toshiba 705T Cellular Phone
Hello, I have tg01 that does not start up. It was running while the battery charge was there but once it shutdown it doesn't come up anymore. I've been charging it for days and the orange light turns on but it didn't help. The battery doesn't feel warm while it's charging either. I've examined the usb port on the phone and there seem to be a broken pin on one end. The contact is there but it may be too short. Is it possible to have the usb port exchanged? Or is the problem more than that? Please help
  • gumino Dec 10, 2009
    Thanks for the expert advice. I'll contact Toshiba.
  • Toshiba Master
  • 19,396 Answers
Hi.
If the USB port has a broken pin, that is surely the problem.
In fact this model uses the USB port to charge, a contact in there may cause the phone not starting, and surely it will prevent the battery from recharging.
The USB connector can be replaced, and it should not be an expensive repair.
To get a quote on repair, you can ask to a local repair shop, but before better grabbing the phone and calling Toshiba at the number listed on phone manual or on their website.
Regards.
Posted on Dec 10, 2009
SOURCE:
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
I have an '05 Honda Civic, and we thought the battery was gone. We jump started the car, and drove it home. We fully charged the battery, but it still doesn't start. Lights are funny, and while...
if your seeing 12 volts after the charge, it doesn't mean the battery is good,, a single cell thats bad in a battery will give you fits and produce the problems you listed,, remove the battery , and have it LOAD tested, that way you will get a true correct reading, a battery can show `12 volts, but a bad cell will not let it charge to the correct amps it needs to start the vehicle. once you've done that , and your sure you have a good battery ,, start the vehicle,, ( make sure that when you replaced the battery , that all the connections are clean and tight) with a meter, place one lead on each battery terminal, you should get a reading between 13.5 and 14.5 volts, if you do , then your alternator is doing its job, if not,, replace the alternator, ( your vehicle doesn't have a generator)
Sep 18, 2011 | 2005 Honda Civic
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
Hello.I've got an Asus K52JE.Today I looked at the
97% isn't that bad, it means that your battery is fully charged but not the whole way. That is bound to happen specially when youre using youre battery a lot. It will get a lot more lesser in the future the more you use youre battery.
The standard laptop battery starts losing the ability to hold a charge after 300 recharges or cycles. If you drain your battery almost completely at least once a month and then recharge it, it will last longer & hold a full charge longer.
Jul 09, 2011 | ASUS Computers & Internet
Start up on acer aspire 5534
you will have to run it in safe mode 1st and run a virus scan, let me know if anymore problems and i will see if i can help.cheers
Dec 12, 2009 | Acer Aspire 5720 Notebook
HP Pavilion ZD8000 - Battery
i have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Nov 28, 2008 | HP Pavilion zd8000 Notebook
Toshiba 705T Cellular Phone Logo
69 people viewed this question
Top Toshiba Cell Phones Experts
Marvin
Marvin
ka4iup
ka4iup
Are you a Toshiba Cell Phone Expert? Answer questions, earn points and help others
