Back to:
Tags:
Lexmark JetPrinter X1185 All-In-One InkJet
Re-detecting hardware looping (by 5 users)
By pawa - usenet poster
I have installed a Lexmark X1185 all-in-one printer.
And, Win XP PRO keeps re-detecting, as a new hardware install.
This was installed correctly.
Then the the popup says "can not install this hardware".
Click "OK". Several seconds later,this starts all over again.
I have unplugged the USB cable, to prevent re-detecting.
I've looked at several websites dealing with XP PRO
problems.
None show this type of problem.
Any suggestions ?
Thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Mar 06, 2008
lost cd, can't install.... pls need help how. Thanks
Comment by lyce, posted on Feb 23, 2008
i installed the lexmark printer to window xp and an installer comes up saying new hardware. i disconnected the cables and it still wont let me print
Comment by rita627, posted on Feb 19, 2008
lexmarkz611
Comment by Guest, posted on Feb 17, 2008
will not print anything on paoer nor on top
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Rachel007
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
/blackbag/ said:
Try Kelly's link, below.  Click on "P"...scroll down to...
Printer - Always Found after Reboot
For most XP answers and tweaks...
http://www.kellys-korner-xp.co m/xp_abc.htm
http://dougknox.com     http://aumha.org
http://support.microsoft.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Re-detecting hardware looping:
I don't want to Accept this solution
Solution #2
Not Rated (0)
kioner
Rating: 0%, 0 votes
Hi Dev,
I'll sure try this one.
Thanks. The problem will be solved.
Thank You!
Solution #3
Not Rated (0)
man1
Rating: 0%, 0 votes
Hi Dev,
Found something interesting:this was a hard drive problem.
Got out my other computer with XP PRO. Installed with no problem.So, swapped
hard drives.
Had to re-install XP PRO.That's OK.
The printer installed without no problems or re-detecting.
Just might have been a bad spot on the drive, causing no registration, and
the looping.
Hope this has helped others.
Thanks again.
Thank You!
Can you Help with these Printers problems?
I put in a new ink cartridge and cleaned the head but it...
some material was dropped inside the printer through the...
one of the little plastic inserts on the paper support is...
solved my problem now can print as always
i download my lexmarkx1100 series cd and it took but when...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
