Question about Ryobi Drills
Chuck removal on a ryobi
Hi, I have a ryobi EID 800 2HE on which the chuck has failed. I have looked inside the chuck but cannot see a screw or alan key to loosen. Does anyone know how to remove the chuck?
Thankyou
Yours Kieren.
  • 2,176 Answers
Go to my site and under the tips section there is a detailed description on how to remove this chuck
Posted on Dec 12, 2009
How to remove a bent chuck from a Ryobi DP101 bench drill press
look inside the center of the chuck... if the is a bold inside, remove it. then place the short side of a 3/8" allen key into the chuck and tighten the chuck... then smack the allen key from the side with a hammer the same direction as forward rotation...
Oct 25, 2013 | Drills
Ryobi 12 volt drill/driver- cannot unlock the keyless chuck
replace the part you have taken out .
get a pair of stilson spanner adjust it so it goes around the chuck and do it and then it will ease off to do it up by hand
Sep 21, 2017 | Skil 2887 - 06 Factory - Reconditioned 18V...
How to change the chuck on a ryobi EID1000RE
hello, there is a screw you have to remove inside of the chuck once you have done this you should be able to unscrew the chuck,,
Feb 07, 2012 | Garden
Model # HJP001 Ryobi 12 volt cordless drill. Chuck is jammed, will not close. There is a screw down inside the chuck but it will not turn.
I just had the identical problem with my HJP001, and managed to solve it piecing together info from this thread. The cause for the chuck to jam was that the retaining screw had come loose and was interfering with the chuck. As others have pointed out, the retaining screw has a left-hand thread, ie reverse from most screws, which obviously needs to be taken into account. Simply tightening the screw solved my problem - together with some WD40 ;-)
Sep 05, 2011 | Ryobi Garden
I have a McCraw Edison 1/2 drill model 3241T2and need a new chuck where can I find one.
If your chuck is a stanard type, fully open the jaws of the chuck and look inside the chuck to see if there is a retaining screw.
If there is one remove it (more than likely it will have a reverse thread).
Using the chuck key in the chuck, knock it with an hammer to loosen it.
You should be able to get any chuck from a local tool shop to fit your drill.
Regards
Alan Hood
ami-man
UK
Feb 09, 2010 | Drills
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Chuck tines on Ryobi Hammer Drill Are Not Engaging Uniformly
home depot replacement chuck i beleive you can also us a keyless chuck. they usually come with instructions. most have a screw at the inside of drill chuck.
tom
Dec 12, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Drills Logo
1,059 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
