Question about Galaxy Radios DX-2517 CB Radio
2517 no transmit ,has recive,maybe keying transistor?where on the main board is it and what is the part#/transistor#,info also where can i find it? thank you jaye
    Novelist:
  • 500 Answers
Is the lights changing from green to red? there is a switching diode near the audio preamp ic. is 70% of most failures.
Posted on Dec 11, 2009
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
Dec 15, 2015 | Cobra 25 WX-NW-ST 40-Channels Base CB...
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Mar 12, 2013 | Radio Communications
Signal strngth is weak
Maybe the stations you are listenning happend to be located quite a distance away. Or your antenna may not match properly. Or the signal indicator may be faulty if the modulation sounds like he is transmitting right next door.
Oct 08, 2012 | Galaxy Radios DX-2517 CB Radio
LOOKING FOR WIRING DIAGRAM FOR SA EX300 TECHNICS HOME RECIVER
SA EX300 Output Transistors are inside these Hybrid IC
Part Number = RSN 3403-P
Aug 01, 2012 | Technics Audio Players & Recorders
Were is the keying final an a DX cb radio
There is no keying FINAL? there is a diode under the mic connector that controls TX/RX keying up.. but if your talking about the Final RF transistor its a 2sc2312,or 2sc1969 both they discontinued, so places still have them. they should be under $6.. but all radios new, are using MOSfet's.. there is a process to do the change on radios that had the analog transistors.
You could send it in to us and we can fix it.
We do not charge to look at any radio -no bench fees-..
Let me know Ill get you any info that you need.
Nov 07, 2011 | Galaxy Radios DX-2517 CB Radio
I HAVE A GALAXY 2517 BASE IT WILL KEY UP BUT IT WONT MODULATE IT RECIEVES FINE
could be a couple transistors or caps near center board. you may check your mic out or mic gain knob.
Jun 04, 2011 | Radio Communications
My galaxy 2517 (NO TX)
if you have another radio put it right next to the 2547. turn on the monitor radio with no antenna on the same channel and key the 2547. if you can hear it the final transistor is bad. let me know if that worked
Jul 18, 2009 | Galaxy Radios DX-2517 CB Radio
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
Dec 10, 2008 | Galaxy Radios DX-2517 CB Radio
No transmit or recive but works on pa mode
does this radio have freq? if so you could have turned on causing
a miss alignment with antena.. check all the switches move into different positions and keep keying up, good antena connection?
swr?
tony
Dec 03, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
199 people viewed this question
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
