Question about Canon CanoScan 8600F Flatbed Scanner
Inability to copy film to pictures
I follow the directions in the manual to copy 35 mm film. However, when I scan all I get is a pictue of the film holder and a tan colored picture of the film strip.
  • 3 more comments
  • Chatta Jan 20, 2008
    there is no option for negatives only platen
    Ok, I have a CanoScan 8600F -- I have to uninstall first, right? Sorry, not real good at this. Don't know how to print screen and get it posted. :-(
    for some strange reason, I cannot print screen. I hold ctrl and then hit print screen and nothing happens. and yes, my printer is on :-)
    This says a web page cannot be found. I have adobe which opens most files.
    I have gone on line with Canon and they said they would reply. Maybe I can get some help from them.
  • 2,427 Answers
When you were scanning, did you set the scan selection to scan negatives ?
Posted on Jan 20, 2008
  • 4 more comments
  • Rishi Roshan Ali Jan 20, 2008
    Take a snap shot of your screen CTRL + PRINT SCREEN and upload it here ( in th box where you type, its the second icon to the top) and we will see whats happening
    Well thats why you cant scan negatives, the scanner has to be set to scan it specifically, Could you post your scanner make and model for me and if you could, a snap shot of the settings part of your screen for the scanner.. While you are doing this, please reinstall your scanner driver as well..
    yeah you have too uninstall first, ok let me do a little backdigging and i'll get back to you in a sec.
    its easy to do a screen capture,
    1.) HOLD CTRL then pree PRINT SCREEN
    2.) Open Paint or any photo shop program, create a new document then press CTRL + V
    :) it copys a picture of the screen to the clipboard, you have to go into paint or any graphics program and paste it there CTRL +V
    8600Fquickstartguide-e.pdf
    http://alpha02.c-wss.com/inc/ApplServlet...
    Ok i found this
    the file you need to downloaf is named
    follow the instructions on page 7 of the pdf manual and you should be fine..
    let me know what happens, BTW you need a pdf file viewer to open the file
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
Loading film in canon tlb
Follow the illustrated instructions beginning on page 27 of the manual.
Sep 27, 2012 | Canon EOS Rebel T2 with 28-90 lens 35mm...
I have a Coolscan IV with the coolscan 3 Software, and i have a mac book pro. The following message appears: Error "Could not send look up tables to scanner.", Please help me
Try upgrading to v4.02 driver. You may need to download 4.0 first as 4.02 may only upgrade from 4.0. The scanner runs with v4.02 on my Mackbook pro but I can only scan using the slide adapter and the film holder at present. The film adapter will not work but i'm not sure if this is a hardware or software problem.
Apr 06, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    Can i scan negertives 35 mm photos
    I looked at the manual and it does not have any references to 35 mm slides scanning.
    The manual:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Jan 19, 2011 | Canon PIXMA MX310 All-In-One Printer
    How do i scan a photo with hp deskjet f340 all in one?
    Place your document or picture on the glass. If scanning film, placethe 35 mm negative or slide in the special adapter provided by HP.Select the Scan Picture, Document or Film button depending on what youare scanning. Select the Make Copies button to copy the document orpicture directly. Click "Scan" and then "OK" to see the scan preview.
    Jan 08, 2010 | HP Deskjet F340 All-In-One Printer
    After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
    It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
    Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
    Coolscan ed 4000
    The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
    Aug 15, 2007 | Nikon Super Coolscan 4000 ED Film Scanner...
    Canon CanoScan  8600F Flatbed Scanner Logo
    157 people viewed this question
    old marine
    old marine
