Posted on Dec 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
##322 - error code. Alarm light will not shut
##322 - error code. Alarm light will not shut off. Fax machine transmits, but does not receive.
  • Anonymous May 11, 2010
    Please supply make and modle
Corne Viljoen
Level 2:
  • Expert 385 Answers
  • Posted on Apr 06, 2010
Corne Viljoen
Expert
Level 2:
Answers
385
Questions
0
Helped
107687
Points
969
##322 is the fuser unit not warming up!Can be replaced and fixed!
Error 322 How to fix it?
There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
2answers
Err code 322 every time ces up on my HP 6600 print scan web copy n faxachine .
Video might not help but 322 is an error with the receiving fax machine due to poor telephone line conditions. Solution is to set the receiving machine to receive at a slower transmission speed if it still fais resend the documents in smaller sizes. Hope this helps
When I send a fax, I get error code 322. I can't receive faxes either.
The error depends on the fax model that you are using. Error 322 on Canon Fax and other machine may significate that the Fuser is not heating (Usually Bad Fuser Module).
A different thing is Comm error 322 on computer, that means that there is no communication, and can be caused by bad phone cable, software problems and hardware problems.
In that case ensure that you are using a fax cable with two poles. If the problem started recently do a system restore to a date before the problem started.
If you get the 322 on display, even when computer is not connected, you usually need to replace the fuser unit.
Regards.
2helpful
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
2helpful
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
2answers
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Canon CFX-L4000 not receing faxes.
##322 is the fuser unit under the cart that needs to be replaced!Good Luck!
4answers
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
old marine
old marine
ZJ Limited
ZJ Limited
