Question about Toshiba 52HM95 52" HDTV Projection Television
60" Samsung HDTV
My screen turns green and flickers. I can sometimes keep it on right once the green goes away as long as my TV is not turned off. Could this be my color wheel going out?
  • Toshiba Master
  • 8,617 Answers
Thats a very good possibility. The bearings in the color wheel eventually wear out. Have you noticed any noises lately when the green is messing up.?
Posted on Jan 20, 2008
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a Aquos Sharp HDTV Model LC-32D62U that is a liittle over two years old. I am experiencing a Green Sceen when switching back & forth between channels. The only way to clear the Green Screen is...
that is the TV reading the HD signal and basically telling itself to allow the HD signal. When that happens there is a flicker of green, or sometimes the screen goes black. It is annoying, but its not just your TV, its pretty much on all tvs. This won't be a problem once everything is HD.
Nov 26, 2010 | Sharp LC32D62U 32 in. LCD HDTV
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv Tech.to change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Sony KP-51WS510 flickering&screen turning green????
Sounds like your focus block is going bad or out of adjustment. It could also be a bad picture tube.
Jul 05, 2009 | Sony KP-51WS510 51" Rear Projection...
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung hl-s6186 screen flickers and sometimes goes green
The humming will usally come from the color wheel(one of the only moving parts), which is part of the light engine. If the tv is starting to get a green picture that is a sign that the light engine is on it's way out.
Aug 05, 2008 | Samsung HL-S6187W 61 in. HDTV
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
