Question about Motorola Mobility W375 Cellular Phone
NO SOUND ON MOTOROLA W375
THE PHONE WILL VIBRATE BUT NO RING TONE SOUND. IT IS SET FOR MAX VOLUME. IT IS NOT SET ON SILENT.EVER THING ELSE OK.
.. IS IT POSSIBLE THAT THE SPEAKER HAS FAILED.
REGARDS.
GEORGE
Not able to put the Nokia E5 phone in Vibration Mode
When you get to your phone's setting, select profiles. Amongst the list of profiles, determine which of them you want to use to activate your vibrate mode.
When you have done that, scroll to that profile, select 'options', then select 'personalise'.
In the personalise sub-menu, you are allowed to set the features of that mode to your desire.
In the ringing tone, select no tone, in the ringing volume, reduce the volume to zero. When you are asked if you want to set the ringing volume to the maximum, select yes/ok.
In the vibrate option, select yes/vibrate.
In the message tone, select no tone.
For other sounds and tones, select no tone.
When you are done, REMEMBER TO SAVE IT.
Then go back and activate that profile.
It is advisable that the profile you use for this though, is your 'silent' profile.
Hope that was helpful?
Have a wonderful day.
Jun 20, 2011 | Nokia E5 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Hi Does anyone know if you are able to set the ringtone to silent and also the incoming message tone to silent (need it for work) on the Samsung F480 Thanks Elkay
In order to set the ring tone to silent you must turn the volume down to silent or vibrate. Go to phone in menu and check on sounds.
Jan 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Silent Turn-On
Hi:
Before turning your phone off each time, reduce your phone's volume to 'Silent'. Each time you turn your phone on, the tone will not sound. Once you turn your phone on again, raise the volume again to hear the ring tone. You can also leave the volume in the 'Vibrate' mode, and it will vibrate each time you turn it off or on.
Tgillen4
Apr 22, 2008 | Motorola Mobility TracFone C139-4 Cellular...
KEY PAD SOUND ON W377
Hello Velveteve,
Luckily for your housemates, there is a way for you to silence the keypad.
You'll need to go to your "Settings" Menu
Select Ring Styles, then go to ringer "detail"
If you scroll all the way down, you should be able to see "Key Volume".
Set that to "0".
Similarly, you can choose the "Silent" or "Vibrate" ringer option and that will temporarily silence your Keypad Tones.
Hope this helps,
cHiPz.
Mar 23, 2008 | Motorola Mobility W375 Cellular Phone
Key pad sound
open ur phone menu first. then go to settings,open settings, then select ring styles,then select second option it can be as ??????detail.(???? = type of ring style u have selected,whther it is loud, soft, vibrating .vibe & ring or silent). just select second option,then scroll down and look for key tone type, select it and choose it as off, ur annoying keypad will silent. thanks best of luck.
Feb 24, 2008 | Motorola Mobility W375 Cellular Phone
W375 1in silent mode always
you will need to have the firmware reflasn the phone and if that does not help, then have the mobile exchange for a new one.
Dec 20, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
130 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
