NO picture. No sound. Screen Blue. Is able to Change channels, and volumn line, but no sound. When use menue on remote, get page says "Can Programa, listed underneath are Cannal, antenna, and last is Autoprograma all in spanish. I scroll down to antenna and to the right get Cable/Air when push arrow right of menue. Scroll down to Autoprograma, push right arrow, and get a red line with movement on it. when the movement finishes, I get picture and voice on the channels right of Cannal. (The channels increases with the movement on the red line, most channels unclear, and some with no voice, depend on what channel stops on the right of Cannal.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps—
1. Turn off the television and wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Also check for swollen/bulged capacitors on the X-sus board and any blown fuse on the power supply board.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 10, 2009
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Fix blue screen av27870
Hi. Switch off (mains switch) the VCR. Then see if you can change channels with your TV remote. Blue screen mostly means that no channel has been programmed. If there is , you should at least have the sound. So, if you have sound, there is an internal problem in the TV. If no sound appears, try to get into setup mode (button Menu)
and programm your channels. I suppose there is signal on your normal areal connection. Check this out with another TV set, or use the tuner from you VRC. I know there are a lot of possibilities, but you can sort this out, step by step. Good luck.
Oct 18, 2014 | JVC Televison & Video
I can't hook up my dvd player to my quasar model v v 1309 because we don't have a remote and can't change the input. The screen is blue and the channels change.
You should be able to change the input mode by changing the channel up or down past the regular channels (so channel down 3, 2, 1 > Line > 125 (if cable source) or 69 (TV source).
A replacement remote can be gotten from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=VV-1309&uuid=12897739886740 . With the remote, press Action and then enter the menu then choose Input Select and then choose Tuner or Line.
I hope this helps.
Nov 14, 2010 | Quasar VV1309 13 in. Combo
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
Went to be with the set working, woke with the
I believe this problem is identical to the fellow who had the power led comes on but no video. Follow the instructions on that one ...case solved. You also have a bad eeprom. If you have more questions, as not finding the problem earlier in this page. Let me know.....It is a simple solution.
Jun 25, 2009 | Philips Magnavox 27MS343S 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
MANUAL BUTTONS
Check the manual page at the link below for instructions on how to use the on screen menu to add channel 3 to the "active channels" list.
http://www.fixya.com/support/p197903-apex_digital_at3208s_32_tv/manual-18780/page-10
Dec 02, 2007 | Apex Digital AT3208S 32" TV
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
