Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
External hard drive is dead
Neither PC nor Mac will connect with my external hard drive.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
I have two dead (power supply) PC laptops that I would like to recover some music and pictures from. What is the most economical way to do this now that I have a macbook pro?
When you put the hard drives into an USB hard drive adapter case you cannot boot up the laptops using the external USB hard drive unless the laptop's BIOS has the option to allow the USB device as a boot device.
You can plug the external USB hard drive into any PC/laptop to copy files from the USB hard drive to the PC/laptop.
The MAC cannot read or write to the external USB hard drive unless the hard drive had been formatted in FAT32. There is no way a MAC can read a NTFS formatted hard drive and it will want to format the hard drive.
Oct 05, 2012 | Computers & Internet
Need to low level format an external mac hard drive
connect it to another pc and open the files
remove any passwords or locks then format it
Nov 14, 2017 | Hitachi Computers & Internet
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
My Book formatted NTFS attaching to Mac
If you want to exchange data files between a PC and a MAC then your My Book 3.0 external hard drive needs to be formatted in FAT32. Use a PC to format the external USB hard drive in FAT32.
If you only want to use the external hard drive on the MAC then use the MAC to format the hard drive in HFS+
Dec 25, 2011 | Western Digital My Book Essential 1TB...
Mac will find wd hard drive PC will not
The Mac disk format cannot see or read by a PC, the PC can see the external drive as a device only.
The way around this problem is to format the external drive with the PC, now you can fransfer/copy files to the external drive and when you plug it into the Mac, the MAC can read PC file formats, this also applies to USB memory sticks.
Aug 02, 2009 | Western Digital My Book Essential 1TB...
When I connect my Maxtor external hard drive to my MacBook Pro, the light comes on, however the computer does not recognize the drive. I've gone into disk utility and it doesn't show there either. Not...
I think I got it. I have a Maxtor and when I connected it to my macbook same thing - light comes on but the computer does not know its there. So I tried to plug it into my PC (i've got it formatted for both - a actually it has 3 partitions one mac, and two pc) well when I plugged it into my PC the Maxtor Manager popped up and said that the drive was locked and I needed to unluck with my password. Once I unlocked it, it worked. I disconnected it from the pc and I plugged it into the mac and it's working fine now. I guess there is no manager for mac. I'm going to the website to see if I can download the manager for mac. Hope this helps.
Jul 22, 2009 | Computers & Internet
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Install screen and drive won't boot up anymore
Hi Doug,
The problem is that mac has a diffrent 0perating system to a pc the thing you doing by switching from mac to pc the external hard drive is conflicting with one another to make your external driver to work on your pc follow these steps. go into control panal,system,hardware,device manager,universal serial bus controllers,drivers then update drivers that should reconise your mass storage driver.
Jan 16, 2008 | Computers & Internet
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
53 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
