Question about Samsung HLS4266 TV
The picture has white dots on the display. It started with a few and has gotten worse. I believe it is a problem with an IC on the digital board.
  • Phil Day Dec 11, 2009
    Thanks for the info. It helped.
    Genius:
  • 1,112 Answers
Hello:
The white dots are mirrors that have gone bad on the DMD Chip (Digital Mirror Device). Its the chip that has about 65,000 mirrors on hindges that tile back and forth depending on the what polarity of voltage is being applied to it. This chip is part of the DMD Module, I do believe you can replace the DMD chip without replacing the DMD Board assembly. But your problem is the DMD chip some of the mirror on it are sticking that is why you see the white dots...
Posted on Dec 11, 2009
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
Hundreds Of White Dots On My Display... Looks Like Stars!
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
Mar 21, 2012 | Toshiba TDP-SP1 DLP Projector
I have a 73" mitsubishi diamond edition tv and
this is when dmd (digital mirror device) ic begins to fail. these dots will become more numerous until they fill the screen. replacement of dmd board will solve
Sep 27, 2011 | Televison & Video
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
White spots appear about 8 in 2 weeks will it keep getting worst all at once or over along period of time
yes it will keep geting worse the dlp is is going bad the mirrors on it are getting stuck they may appear as black dots or white dots. the dlp ic needs to be replaced
Jan 29, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
Aug 15, 2009 | Televison & Video
Request for Top EXPERTS '' Picture Shades''
You have to replace the Display IC
Jul 04, 2009 | Televison & Video
Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Feb 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Samsung HLS4266 TV Logo
301 people viewed this question
Jerry Greenberg
Jerry Greenberg
