Question about Poulan Garden
Poulan Pro Hydro 18.5-42 riding lawnmower- no drive...are there shear pins in the axle drives?
  • 430 Answers
First check that the purge valve is not engaged. Usually a small rod sticking out the back plate of the unit toward the right side. It should be pushed in.
Next check your drive belt. Best bet is to remove the deck and lay under the unit. Check for locked up pulleys and that the belt is seated properly on all the pulleys and that the belt is not stretched, cracked, or burnt. Make sure the belt gets taught when brake/clutch is released.
Lastly, there are keys in the drive axles. I have never seen one fail but they do get lost on occassion when the wheels are removed.
Posted on Dec 10, 2009
SOURCE:
How do I unlock the rear wheels, I got a Poulan Riding Mower from a late Uncle. It won't roll forward or backwards
Kevin, if it is in neutral or if it is hydro-stat, you have pulled the pins in the back to unlock the axles. the brakes may be locked up. the last two mowers i got for some reason the brakes were locked up on them both. hope this helps.
Dec 16, 2016 | Poulan Garden
Changed rear flat on ariens 42 in riding mower put tire back on now mower will no move any more. worked fine when I pulled it up to take tire off
I feel you have lost the shear pin that goes on your axle. The shear pin goes in the little groove in the wheel It may have fallen out when you pulled the wheel off.There are also safety pins in the belt drive pulleys
Oct 27, 2016 | Ariens Garden
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
Hit a stump with lawnmower, now wont start
You may have sheared the flywheel key. This throws the timing off. If the shaft isn't bent replace the key.
Jun 22, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Removed the deck on my Poulan pro to replace the sheared pins on the broken spindle. Now the mower wont go into gear?
You might have knocked the drive belt off while removing the deck/belt? what kind of transmission do you have 6 speed manual or an automatic?
May 16, 2014 | Mtd Garden
Transmission Locked up on Poulan Pro 18 hp
Is this a riding lawn tractor with a snow blower attachment? If so, I would inspect drive belt underneath unit to see if it slipped off and is locked up. If belts look ok, try pulling hydro release to see if you can push unit. If not your problem sounds internal.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Feb 18, 2014 | Poulan Garden
Were do you put hydro drive oil in. I have a 700ex
Hello, sorry to be the bearer of bad news, but the trans-axle on this is a sealed unit and oil cannot be added. The only thing you can do is an air purge or replace the trans-axle.
Doing a purge is really easy:
  1. put transmission in the freewheel mode so you can push it, ensuring that it is on a flat surface
  2. start engine and run full throttle
  3. release clutch brake
  4. push the drive pedal or lever to the full forward position for a ten count
  5. push the drive pedal or lever to the full reverse position for a ten count
  6. repeat steps 4 & 5 three times
  7. depress & lock the clutch brake
  8. return the transmission to the normal mode
  9. drive tractor
If this fails to correct the problem you may need to replace the transaxle.
If you find this helpful please vote yes. Thank You!!
May 12, 2011 | Poulan Pro 46Inch 22 HP Yard Tractor with...
I just purchased a Poulan Pro PP208E24 model snowthrower from Costco in Ottawa, ON. I have assembled the unit per the manual. The problem I have is that the unit does not seem to have a neutral position....
According to the manual; remove the klik pin (holds wheel on axle) and place it in the outer axle slot to disengage drive system. Replace klik pin to inner axle slot for normal operation.
Works for me.
Sep 04, 2010 | Garden
Shearing of flywheel pin on starting 12 hp snapper
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
Oct 29, 2009 | Garden
Garden Logo
217 people viewed this question
Top Poulan Garden Experts
roeb
Jay Finke
Jay Finke
dannydoesita
Are you a Poulan Garden Expert? Answer questions, earn points and help others
