The set turns on and there is audio. the backlight shows dimly but there is no video. I am using the composite input but component input is the same. I have ruled out the digital board.
  • Phil Day Dec 10, 2009
    Rylee, this set is a plasma tv Sylvania 6842PFM. The power supply turns on and the digital board is new.
    Phil
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The fault protection circuit has detected a fault and has turned the TV off. You'll need to check various things to find out which part is bad. Please check these---
1. Check for signal cables at the back and also try unplugging the TV for 8-10 hours to reset it.
2. Also check for any swollen/bulged capacitors on the power supply board. This happens due to overheating of capacitors.
3. If the capacitors are fine then you'll need to check for connectors on all the boards and also the fans if they are working fine.
4. Make sure the lamp connections are fine and ballast is not burnt.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 10, 2009
  • Rylee Smith
    Rylee Smith Dec 10, 2009
    Hi Phils
    I am really sorry that I just read the Heading which was
    showing Projection TV troubleshooting and didn't request you to provide me the
    make and model # and provided the solution for it. A plasma TV needs twice
    as much input current as any other TV. Unplug the TV for more than an hour to
    drain the current. If still the issue persists, then it means that some
    components might have failed or gone bad. These sets uses cold solder
    connections. Whenever a problem is detected by the safety circuitry it will
    shut off the TV to avoid further damage to the unit. There are more than 2,000
    parts including millions of transistors inside the integrated circuits.
    You’ll need to check the leaking or bulging capacitors which might be required
    to be replaced to resolve the issue. If still the issue persists then it might
    be due to the high voltage shutdown which might be exceeded 33k and the unit
    shuts it self down to protect other parts being damaged. As the power supply is
    new, please check power supply regulation and horizontal circuits. If these are
    fine then it means SSB has gone bad. You’ll need to replace SSB. The
    other possibility is X sustain Y sustain and buffer boards which controls
    picture, fires the gas, and many other functions. No image is a very common
    problem. It is always better to replace both sustain boards. If you feel that
    you are qualified to diagnose and repair the TV then go ahead otherwise it
    should be done by a professional TV tech. However, be careful while doing
    repairs on any TV because there is always high voltage present even when the TV
    is in off position.
    Thanks
    Rylee
  • 11,896 Answers
I would say ballast or light bulb is faulty. Could be high voltage transformer but since you have audio, I would rule that out
How to connect composite and component
Your description is somewhat confusing. Most TVs today have component inputs with limited composite inputs. If you have the red green and blue video input Jacks, that is component. The single Yellow Jack is composite. There are adapters available on the internet. You don't need audio in the adapter because audio out to audio in from DVD to TV is the same regardless of the video input. Another option if your DVD is the single yellow output is to convert that to HDMI for which adapters are available. Hear you do have to use the audio jacks to the converter for the HDMI cable to function. Otherwise more information is necessary.
Jan 02, 2018 | Televison & Video
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
TH-50PX77U inputs
Many times a computer's post screens will not show up a TV set, and once the computer itself has loaded the drivers and settings, the set may need to be shut off and turned back on for the HDNI or PC signal to be detected.
It is also possible the settings you selected for display properties cannot be displayed on the TV.
As far as the component video signal, are the connections correct? Sometimes people mistake the composite red, white and yellow for the composite system that divides the red, blue and green video signals.
While also possible, but rare- there may be poorly soldered connections on the "A&D" board (logic board) .
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
How do i connect my wii to my new samsung ue46d6530?
Input &
Output
HDMI 1.4 (3D Auto Setting/Return Channel):4
USB:3
Component In (Y/Pb/Pr):1
Composite In (AV):1(Common Use for Component Y)
Digital Audio Out (Optical):1
PC In (D-sub):1
CI Slot:1
SCART:1
RF In (Terrestrial / Cable input):1
RF In (Satellite input):1
Headphone:1
PC Audio In (Mini Jack):1
DVI Audio In (Mini Jack):1 (Common Use for PC Audio in)
Audio Out (Mini Jack):-
Ethernet (LAN):1
Initially I thought the problem was going to be no composite input on this television. However according to the specs there is one composite (yellow, white, red) input and that is where you connect the wii. Is the problem that you've already connected something to the one input and you're looking for another spot to connect the wii? There is a wii component cable http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
Jun 13, 2011 | Samsung Televison & Video
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Have Audio, and backlights, but still no video on Polaroid 3732
try the diffrent inputs HDMI Composite component and see if the video comes on there are 4-10 diffrent inputs on these sets and make sure you select the right input on the menu the remote has a button for inputs a menu comes up and make your selection from there for the right input that you have connected to the tv most menus have TV (air) HDTV (air) video 1-6 HDMI and VGA
Jul 02, 2007 | Polaroid FLM-3732 Television
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
