Question about Sony CDX-M630 CD Player
It want work at all
Ok it was working then one day i came to the car it stop working i test it on a batterie it wouldny come n i test it an my fuse box not work i look at my fuse it was good .
  • 111 Answers
The problem is the ribbon cable,the one connects the face to the main board.
You can get it from pacparts.com
part number is 168518411
Posted on Jan 20, 2008
2010 jeep liberty heater/blower and front only windshield washer both stopped. check fuses and all good . Is there a relay in fuse box that affects both and which one is it.
shoe falls off other foot and car drives perfectly?????????
why not ask or learn how it works first?
scan it yet, be super wise to scan all modern cars, first.
or chase tail,like a puppy you will.
VAST DTC ERRORS POSSIBLE OF HVAC !!!!
if all fuses test ok, then you answered you own question.
sure , is car in USA? be nice to say
is car , USA KK jeep? 08-2012
BATTERY NOT DISCHARGED, AT ALL,
we test fuses, ones look bad are.
ones look ok we test.
lacking the service manual.
wipers ok>?? one more shoe falls off foot.
are all things on car working except what you said?
blower fails on high, i work just that prob.
is HVAC, manual or the aTC AUTO SYSTEM
TOTALLY DIFFERENT SYSTEMS.
FUSE M34,HVAC
FUSE J21, WASHER.
Feb 01, 2017 | 2010 Jeep Liberty
Cigarette liter stopped working then the next day the blower motor stopped working, Now the buzzer for head lites being left on stopped working and interval wipers stopped as well. This has been within a...
no power, means, what, cig lighter plug dead,?
try something else there, like a cell charger, still dead.?
if it is truely dead, the fuse is blown.
does head lights work, and engine run?
ok fuses that bad are bad, blown. (blown elements)
ok fuse that look GOOD, can in fact be bad, (tiny cracks.)
we never fail to test good looking fuses or go nuts for sure.
you can test fuse 3 ways.
1: DMM ohms, 0 ohms reading
2: voltmeter shows, 12v, on both sides of fuse, key on.
3: a fuse tester dealy bob at any autostore. (ill pass)
there are other ways, but are way too complex to type.
(ok a battery powered test light , yes, all auto stores sell them.
glow with a good fuse)
bingo?
Sep 03, 2013 | 1991 Honda Accord
Electrical Problems
HAVE THE BATTERY LOAD TESTED BY ANY AUTOZONE OR ORILEY AUTO PARTS, IT IS FREE. All THE SYMPTOMS YOU HAVE ARE FOR A DEFECTIVE BATTERY.
Jul 12, 2012 | Cars & Trucks
Chevy cavalier - rear brake lights don't work. The center rear brake light does work as well as all other lights. Replaced the bulbs and fuse - no luck. From what I have been told, the turn signal...
Stop Lamp Circuit Description
The STOP HAZ fuse in the IP junction block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to the center mounted stop lamp (CHMSL) and both left and right stop lamp assemblies. The left stop lamp is grounded at G304 and the right stop lamp is grounded at G304.
Check the ground ! Testing an not guessing is the way to find the problem . Do you know how to test automotive electrical systems an circuits using a DVOM - digital volt ohm meter ? How to use an read a wiring diagram to pin point testing areas in a wiring harness ?
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Stop Lamps Inoperative
Step
Action
Yes
No
Inspect the 20 Amp STOP HAZ fuse.
Is the STOP HAZ fuse open?
YES - Go to Step 11
NO - Go to Step 3
Use a test lamp in order to backprobe connector C1 of the brake switch connector between terminal A and ground. Refer to Circuit Testing in Wiring Systems.
Does the test lamp light?
YES - Go to Step 4
NO - Go to Step 5
With the brake switch closed, Test for positive battery voltage at terminal B of connector C1. Refer to Circuit Testing in Wiring Systems.
Is voltage present?
YES - Go to Step 6
NO - Go to Step 7
5
Repair the open or short to ground in the Fuse Output-Battery between the fuse block and the brake switch. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
YES - System OK
6
Use a test lamp in order to backprobe the turn/hazard headlamp switch assembly connector C2 terminal A and ground.
Depress the brake pedal.
YES - Go to Step 8
NO - Go to Step 9
7
Inspect the adjustment of the brake switch. If the adjustment is correct, replace the brake switch.
YES - System OK
8
Replace the turn/hazard headlamp switch assembly.
System OK
9
Repair the open in Stop Lamp Switch Output between the brake switch and the turn/hazard headlamp switch assembly. Refer to Wiring Repairs in Wiring Systems.
System OK
10
With brake switch open test terminal A of the brake switch for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
YES - Go to Step 11
NO - Go to Step 12
11
Repair short to ground in Fuse Output-Battery Circuit. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
12
Test the Stop Lamp Switch Output Circuit for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
YES - Go to Step 13
NO - Go to Step 14
13
Repair short to ground in the Stop Lamp Switch Output Circuit. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
14
Test terminals F,G,B and C on the Hazard Warning Switch for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
Go to Step 15
15
Repair short to ground in suspect CKT. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
Jul 03, 2017 | 2000 Chevrolet Cavalier
The car just stopped one day. The lights on the inside will not come on, no radio, and no head lights. I put in a new battery and had the altenator tested. That came back good. The fuses are all good.
Check the mechanical condition of the battery cables; I have seen cables more than once that appeared OK but battery acid had crept under the plastic insulation and dissolved the copper inside.
I confess that this normally shows up first with hard starting or noticeable dimming of the headlights when other accessories are turned on but you have done the other things I would have checked already so it's time to check the cables coming off the battery at both ends.
Apr 19, 2009 | 1997 Nissan Maxima
1988 volvo again, 240 DL battery / start problems.../
hi check/ clean all fuses they corrode /where the fuse connects in the holder i use a phillips screwdriver to clean the brass ends and replace the fuses they (they may and do loose contact under load which will stop the car from charging and flatten the battery good luck hope it works out
regards ray w QLD OZ
Mar 29, 2009 | 1988 Volvo 240
Was pulling fuses and now the wipers dont work on my C240
hi,first bring your battery to battery shop,test or charge the battery,then install,check the alternator changing rate,if ok then try to fine out which consumer is consume the battery with out switching,also check the bulb or connection of trunk lightty,
Mar 21, 2009 | 2001 Mercedes-Benz C-Class
1990 Mercury Cougar windshield wipers won't work
check ALL fuses..check the wire connections at the wiper motor..un plug then plug in .the way to test the motor is to get some speaker wire (stop laughing) go from the battery to motor to by pass the switch .
Dec 23, 2008 | 1990 Mercury Cougar
One phone just stopped working
some DECT handsets have an internal fuse and please swap the batteries to check if both batteries are Ok
Nov 27, 2008 | Vtech Cordless 6041 Phone
Sony CDX-M630 CD Player Logo
56 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
