Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Sink drain water backing up in dishwasher---is this dishwasher or plumber issue
  • 96 Answers
Sounds like you have a pluged drain line I would start with the plumber
Posted on Dec 12, 2009
2 Suggested Answers
  • 56 Answers
SOURCE: Dishwasher works and drains ok, but as it sits
if the water is dirty you need a plumber, if clean appliance repair tech.
Posted on Feb 08, 2010
Sink backs up with water when running faucet,dishwasher does not drain,all pipes under sink clear
We had this problem and found out that the pipe leading away from the house was clogged. Have a plumber look (with a camera) down your clean out, and see if that is the problem. They can snake it from the clean out and clear out tree roots or whatever is the problem.
Feb 14, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
My mother has cancer so needs me to research her problem with her dishwasher. My mother's sink drain water is emptying into the dishwasher. It has to be manually removed since she does not cook much and...
Problems associated with water from the kitchen sink back filling into the dishwasher are caused by the drain line on the dishwasher not having a high end loop. In simple terms, the dishwasher line is too low and is providing a path for the water to flow in the wrong direction. Reposition the drain line so that it loops just above the sink drain. Then, anchor it to the wall so that it does not move. This will provide and air gap and creates just enough resistance to keep the sink water from entering the dishwasher. I have included a link to a webpage that illustrates what I am referring to:
http://homeimprovementteam.com/standing-water-in-dishwasher
If you have any further questions, please post back and let me know. I hope this helps you.
NOTE: If you are experiencing problems with the sink draining as well, then you may have a plumbing releated issue.
Nov 14, 2010 | Maytag Dishwashers
Won't drain water and backing up in sink
You have a clogged sink. Do you own a snake? (do not use any "liquid plumber" type cleaners in a kitchen sink as you wash and prepare foods in it).
Dec 19, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
2 weeks ago, I had a plumber come and put in a new garbage diposer and since then somewhat old/dirty water seems to be sitting at the bottom after all cycles are done. I calle dhim back and he says that...
There is a breakaway stub in the garbage disposal's dishwasher hose port, it needs to be removed before connecting the dishwasher drain hose when installing the disposal.
Disconnect the dishwasher drain hose at the disposal, get a screwdriver and, insert in the disposal's dishwasher drain port and tap on it with hammer until it breaks off. Then remove that stub from the sink side.
Oct 14, 2009 | GE 24 in. Profile PDW7800 Built-in...
No water coming in after sink blockage
Sounds simple , but the plumber may have shut the dishwasher water off. Valve is probably under the sink or near the machine in the basement or crawl space. Good luck.
Jul 04, 2009 | Asko 1385 Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
115 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
