Question about Hamat 3-3141PC Country Classic Bar Faucet with Lever Handle Polished Chrome...
It is leaking---how do you disassemble the top to get to the o-rings? Thanks! Rick
Oil leaking from silincer of dirt bike
Dear Jesus
The oil ring on the piston may worn out or broken causing engine oil leaks to the combustion chamber and exhausted as unburnt through silencer. As the result it consume more fuel, shortening of spark plug chocking of silencer etc.
This may also happen the overflow of fuel through carburetor.
It has to be replaced for which the engine to be disassembled.
Thanks.
Feb 27, 2015 | Motorcycles
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Blocked aircondition frm front face/leg but only flows from the front windscreen recently replaced cabin filter still no luck, car saab 2001 9-5 4 cylnder puting load on battery! Can yu Help.. Thanks
I believe the part of your control that opens and closes the different doors inside the heater box has some faulty "O" rings and is letiing the vacuum leak off or leak across the control valve. This requires removing the control panel, disassembling said panel and replacing o rings utilizing a VERY LIGHT coat of lithium grease or mineral oil on each o ring. Be sure all parts are kept hospital clean. One speck of dirt and you could have the same problem of vacuum leaking across all over again. Good Luck
Apr 03, 2011 | 2001 Saab 9-3
I have an exhaust leak at the manifold. Do I need to replace the flange gasket and the O ring. My question is will I ruin the flange gasket when I disassemble it to replace the O ring?
Yes, any type of gasket or seal on your exhaust will not reseal properly. Exhaust seals have a "crush seal" . Once crushed will not be reusable.
Please take a moment and rate my answer........Thanks
Dec 01, 2010 | 2002 Jeep Liberty
GE Washer model # WLSE3150A0WW. When spinning, the tub is significantly out of balance. Clothes have been redistributed to balance the weight. All 4 suspension rod and spring assemblies are in place and...
There may be damage to the balance ring which is situated on top of the basket. This hollow ring is partially filled with fluid which will move to compensate for an unbalanced load. Normally this model would be able to handle up to 5 -6lbs of unbalanced load on one side without significant movement. If the fluid has leaked out it would have a hard time with a slight unbalance. Without some disassembly, it will be difficult to tell. A couple of quick things to look for would be: If the ring still has fluid, you might be able to hear a slight sloshing sound when you move the tub back and forth with your hand. If it has leaked you might see clear droplets that have a greasy feel between you fingers and do not evaporate like water would. That is if it has not been washed away during use.
Sep 06, 2017 | GE Washing Machines
I have an Excell Pressure Washer Model VR 2522, it is leaking from the botttom but can find its exact location of the leak, have all the part but can't find the leak and don't know what area it's leaking...
Hi and welcome to Fixya. Your model has the A14527 Pump assy on it and they are notorious for the pistons leaking due to blow by and the 16 MM seal on the piston starts to leak near the drive shaft.
In addition the O-rings #2950 that mated the piston housing leak. Add to that the 4 o-rings that mate the pressure head to the pump also leak.
See this manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/A14527/A14527.pdf
There are a BUNCH of parts in this pump. One mistake and it will not work when you get done working on it. Be careful what you disassemble.
The seals that leak are items 4, 15 and 16 in the manual.
There can be other leaks.. the ones I pointed out are the most common.
Thanks for using FixYa.
Kelly
Apr 13, 2010 | Garden
Just replaced o ring kit in my nv 83a2 coil nailer and now it leaks from the top what else could be wrong? thanks bruce
did you lube all the o rings and if so did you also check the rubber seal that fit onto the ports in the cap? If everything else appearred fine then find a deal blow hammer or a block of wood and with the air plugged in tap on the cap to seal the cylinder, sometimes during assembly it sticks down and won't seal properly, I would try that before disassembly. Let me know if still an issue.
Jan 10, 2010 | Hitachi NV65AH Siding Nailer, Coil,...
Does the ring expander go on the top or bottom ring?
In a 2 ring configuration, the compression ring is the top ring, and the expander is the bottom. In the manual, the order of disassembly of the rings, the compression ring is removed off the top first, then the expander.
Hope this helps
Mar 15, 2009 | 1971 kawasaki Mach III H 1B
Washer leaking from bottom of tub
If you have the tub out the seal can be removed by taking the brass ring off the shaft, its on top of the seal, then grab the seal with a pliers or pry it out with a screwdriver etc. The new seal will cost about $40-$50. when you put the new seal in put the rubber part on first, careful to not tear it on the slot cut in the shaft to mount the basket. Next put the old brass ring on top of the new one, use this to push the new ring on, this will help get it over the notch for mounting the basket. When the new ring is ontop of the seal remove the old ring, reassemble, check for leaks.
Jun 08, 2008 | Frigidaire FWS833A Top Load Washer
Hamat 3-3141PC Country Classic Bar Faucet with Lever Handle Polished Chrome... Logo
65 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
