Sir i have bought usb mp3 player circuit board , inee how to connect what are the other things reqired with diagram
Visit this blog for your solution. u need to post photo of your circuit to solve problem
Posted on Dec 25, 2009
Fix broken USB connection for MP3 player
I don't think it is possible. Or you must have good electronic skills, including the skill to solder small parts on small circuit boards. Although you did not mention what player you have this issue with, just buying the new connector could cost like 10 dollar or more, when you only order one (or less than 100). So rethink if it is worth going for repair.
Feb 17, 2015 | Visual Land Audio Players & Recorders
Coby MP3 USB port loose and wriggly?
If you know anyone who can solder surface mounted parts they can probably solder it back. Sounds like usb connecter has come loose from the circuit board.
May 09, 2014 | Coby MP-C582 MP3 Player
Ineed a usb cable for a t10 iriver mp3 player
Computer shops sell USB cables. Take your Iriver player with you to the computer shop because the USB cables come with different size connectors and you need one that fits your player.
Mar 03, 2013 | iRiver Audio Players & Recorders
I bought a sylvania mp3 smpk4083 mp3 player and it orgianlly worked with my computer, but now when I connect it to my computer it turns on my player, but won't be regonized by my computer? How do
Same thing happened to me with an IPOD. When I plugged it in to one of my USB ports, it ******** up all the USB ports. I suggest reinstalling the drivers for your USB Ports. Then install the software that came with your MP3 Player before replugging it in. Good luck :)
Apr 01, 2012 | Sylvania SMPK4083 Digital Media Player
My pc window can not recognize mp3 player
Hello
Connect your Sansa MP3 player to more than one USB port on your computer. Ensure that your computer USB port is not corrupt or disabled by testing at least two available ports. This is especially useful when you possess no other USB-based equipment.
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled.
Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Scan your computer for new hardware changes. From the Device manager, click the "Action" menu and select "Scan for hardware changes" while your Sansa MP3 player is connected. Allow your computer to attempt to find any physical component recently added in the event it failed to previously detect it.
Connect your Sansa player to a different computer. Test the connection on a different system's USB port to verify that the Sansa device's own connection has not been damaged. Inspect the USB ports on the computer in question as well to eliminate the possibility of both systems having problematic USB ports.
Change your Sansa MP3 player's USB plug. Sometimes the head of the plug may lose contact with the appropriate circuits. Obtain a secondary USB port at your local retail store and test it on an updated computer system.
Nov 14, 2010 | SanDisk Sansa e250 MP3 Player
When i safely removed my MP3 from my computer after charging it, i try to turn it on and it won't turn on.
Either the battery pack is dead, or ribbon cable connections between battery and circuit board or usb to circuit board is bad.
Oct 31, 2009 | Mpio FL100 MP3 Player
IPod Not Working
Does your iPod come on? If not, your battery could be bad.
If you can see the music playing, but cannot hear anything, you could have a bad earphone jack or a bad circuit board.
You can tell if it is the battery the iPod will not come on at all unless it is attached to the computer or to a power outlet.
If you can move the earphone jack around while playing music and hear something, then it is the headphone jack. If you move the jack around and hear nothing, then I would suspect the circuit board.
If you have a device that can play your music out of the USB port on the iPod, you can make sure that it is the circuit board that way. When the circuit board is bad, music will not play out of the headphone jack or the USB port.
Hope that helps.
Dec 09, 2008 | Apple iPod MA446LL/A MP3 Player
SAMSUNG U3 MP3 PLAYER HELP!
sir kindly check the connector and clean the usb port using lighter fluid...thankksss and hope too help you
Nov 28, 2008 | Samsung YP-U3 MP3 Player
Help do ineed drivers4 player
You don't need a driver for this MP3 player in order for it to be recognize by your computer, just need to connect it properly to a USB port on your computer and wait for about 30 seconds to a minute for your computer to fully recognize and install the necessary drivers that it needs, if its not recognize by the computer try to connect it on a different USB port on your computer....
Oct 20, 2008 | Electronics - Others
Goodmans gmp32g5
Try to force recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 26, 2008 | Omnifi DMS1 Home MP3 Player
1,616 people viewed this question
 Grubhead
Grubhead
