Question about Dryers
Dryer repair I have a front load dryer that will not work. I was at one time able to unplug the dryer to reset it, but that doesn't work now. All the lights on one side quickly flash at all times. I have tried to pull codes off the dryer, but the only code coming up is "re5" which is not in my code book. What else do I need to look for in order to fix my problem with this dryer.
  • 1 more comment
  • jcbc Jan 20, 2008
    frigidaire model no. gleq2152e
  • Anonymous Feb 26, 2008
    I have the same problem. I get error code: "rE5". Dont really knwo what it is. I have dryer: FEFB9200ES. Front loading electric dryer.
  • Randy Bell
    Randy Bell May 11, 2010
    Start by reposting with a make and model number. Can't help you without it.
boffy1970
  • 18 Answers
SOURCE: Sony Tv Problem
standby only usualy flashes when child lock is engaged...normaly a hard reset is in order...
Posted on Aug 10, 2007
Soulvisitor
  • 1113 Answers
SOURCE: TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes.
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Posted on Nov 27, 2007
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
SOURCE: Kenmore He2 front load dryer
cant seem to find a fault code f 26, if you remove the top panel on your machine there should be a tech sheet explaining most f codes on the right side in an envelope, if not remove bottom panel (its in there somewhere)
Posted on Feb 26, 2008
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
Affinity dryer will not start beeps three times
Good Afternoon Friend,
I understand that your Frigidaire Affinity dryer, model# ATF7000E, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home'sicon1.png circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 29, 2014 | Frigidaire Affinity ATF7000E Front Load...
Kenmore he2 front load dryer
door switch error...implies the door is ajar..or that the switch is not working.
Feb 26, 2008 | Dryers
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
Sep 07, 2012 | Whirlpool Dryers
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
My whirlpool cabrio front load dryer will power on but when you press start it doesn't. All it will do is light up under "sensing" but never moves on to actually dry the clothes. I have...
heatman101
Aug 18, 2011 | Whirlpool Dryers
Control lock button is on and will not clear to wash clothes
Hi, Whirlpool makes their control lock very confusing. Often times, people will look on the control panel and the control lock light will go on and they can not figure out how to unlock the control panel. They will try pressing and holding the cancel button and unplugging the washer or dryer to reset it. None of these options work. All you need to do is press and hold the end of cycle button for 3 seconds and the control panel will unlock. If that doesn't unlock your controls, then unfortunately your interface control board is just shorted and will need to be ordered and replaced to fix the issue.
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dryer not working
thermostat on top of dryer heater may need to be reset . Unplug and remove top and just push gently the thermostat (red) you may hear it click .now reset or perhaps a lead as broken to the dryer heater .
Jun 28, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Kenmore he4t front loading dryer stopped working
did you clean the lint?
is the way the airflow goes not blocked with residue??
Mar 19, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dryers Logo
Top Dryers Experts
