Question about Kenmore 24712 Top Load Washer
Kenmore 24712300 won t work after soaking cloths
Kenmore won't work after soaking cloths overnight
4 Suggested Answers
  • 58 Answers
SOURCE: kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Posted on Jul 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore washer not spinning water out of cloths
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do I get the Oasis HE soak clothes overnight.
Unplug the washer after filling the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 22, 2011
How can I soak clothes overnight?
1. Open the door to force a soak.
2. Unplug the unit if you're able.
3. Shut off the circuit breaker.
Sep 02, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washing machine won't spin clothes are soaking wet
See if you can look inside the bottom or the back of this machine for the belt. The pump belt may be slipping or broken, sometimes causing this problem. Be blessed.
May 12, 2013 | Washing Machines
Dishwasher does not clean tea stains from teacups- we have tried a variety of soaps and have used sani-clean. Machine is only one month old- new fully integrated model.
Method #1
  • Wet a cloth then rub the inside of the mug with baking soda. If the stains are stubborn, soak overnight in hot water and baking soda.
Method #2
  • Soak the mug in bleach OR vinegar for several hours or overnight.
Method #3
  • Fill mug with boiling water, add two spoonfuls of dishwasher detergent then soak overnight.
Method #4
  • Try a paste of corn starch and vinegar, apply and let sit for a few minutes then scrub away.
Method #5
  • Drop two denture tablets in the mug, pour hot water over top then soak overnight.
After soaking mugs and removing the stains, rinse and wash very well before using-especially when using the bleach method.
May 06, 2011 | Samsung Dishwashers
Why are the coffee cups still stained after the dishwasher is finished, but all the other dishes are clean and santized
Coffee stains are just one of those things that your dishwasher just isn't going to remove. I assure you they are sanitized and safe to use. That being said there are some things you can do to remove the coffee stains.
Use a damp cloth to scrub out the inside with baking soda. Soaking overnight with hot water and baking soda may also work.
Soaking in bleach or vinegar over night. It goes without saying but make sure you rinse your mugs well if you decide to do this.
Fill with boiling water and a tablespoon of dishwasher detergent soak overnight.
Scrub with a paste of corn starch and vinegar. Leave on for 30min - 1hour and rinse.
Interestingly enough denture tablets have also been known to remove coffee stains. Toss a few in there and soak overnight.
Feb 28, 2011 | Frigidaire Professional Series 24 in....
Lime scale appears on glass parts
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Jan 10, 2011 | Russell Hobbs 10789 Glass Lid Cordless...
We have a black@decker stainless dome kettle (red) electric kettle. we've used it for a couple years and it works great, but there are deposits inside basin that we can't get off with soap/water. they're...
Jan 01, 2011 | Black & Decker Black Decker Brushed...
I just poured water from the electric kettle and discovered LOTS of lime deposits. Scrubbing didn't get all of it. What can I do to clear out the lime (I'm assuming that's what it is - looks like...
Dec 29, 2010 | Zojirushi CD-LCC50 Electric Kettle
What is the best way to clean this kettle - particularly the rim in the top where the limescale has built up and the resin base
Dec 06, 2010 | Alessi MG32 Cordless Electric Kettle
Where can I get a new filter disc for my alessi bird kettle
Dec 07, 2009 | Alessi 9093 Cordless Electric Kettle
Kenmore 24712 Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
