Question about Ariens Garden
Where do you find the oil filter on snowblower model 924120?
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
what does the manual tell you about engine oil
Nov 24, 2015 | Garden
Oil for a snapper snowblower 16223
I found the manual for you snowblower, and it's a two stage snowblower, so I am assuming you need two stage oil. Ultimately you need to get that information from the engine manual, and you haven't provided the engine information in you posting. This is the link for the blower manual:
http://dl.owneriq.net/1/121253fa-ec8b-4e20-b0b5-265321e0c7bf.pdf
Mar 01, 2014 | Snapper Garden
How to start my snowblower model #247 886911
check gas and oil
put full thottle
full choke
prime 3 times
pull cord or electric start
repeat if doesnt start
Dec 25, 2012 | Craftsman Snow Blower / Snowblower Bottom...
I was given a Toro 521 Snowblower. It won't start. I replaced the plug, gas filter, air filter and gas line. Still won't start. Also drained the tank and added new gas
If you replace the carburetor needle seat and bowl gasket it will do the trick. Look up your model snowblower at www.arcolawn.com and you can have them shipped.
Good luck
joe
Feb 14, 2011 | Garden
How would I drain the oil from my craftsman 8.5 26 snowblower, model 536.886190
There should be a oil drain at the bottom of the motor.it should be a plug at the base of motor or below the oil fill.
Nov 19, 2010 | Garden
Snowblower was running for 1 hr. i shut it off when i restarted it ran 1 minute and stoped could not get it started, it it sat for 6 hrs. and started but would not run at higher rpms. it seemed to sputter
Hi. And welcome to FixYa. I am Kelly
From the symptoms you describe it sounds like the low oil sensor is shutting of the ignition.
i.e ran for 1 hour... hot oil... / low oil level ignition cut off. Sat for 6 hours all oil now in crankcase... started and higher rpm sputters....
Check the oil level. Other than that I think everything is fine.
If not please respond with a "make and model" of your snowblower. After that, there is more that we can do to resolve the problem.
Thanks for using FixYa!
Kelly
Feb 11, 2010 | Garden
Garden Logo
140 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
