Question about Panasonic SDR-H18 USB Hard Drive
Cannot get the darned thing connected to my computer.did get the image mixer installed,but now they want me to connect the usb to the camera and computer...is the usb the thing with 4 colorful plugs and one plain one on the other end,or did they forget to send me the right part? help!!!!! had the camera for a couple years already,and am gonig crazy with it.
  • 473 Answers
SOURCE: Connecting the camera via USB hub.
Use of a USB hub for connection does not guarantee normal operation. Try attaching the USB cable directly from the D-snap SD Camera to one of the built-in USB ports on the PC.
Posted on Sep 06, 2005
SOURCE: Panasonic SDR-H18
You also have to plug it into the power source. They put it together with the charger. Get the charger and you will see that you can plug the AC adaptor cable in the other end. This allows you to power up when you are using the USB.
Posted on Dec 26, 2007
SOURCE: Panasonic VDR-D250 - PC Connection problem
I have the same camera did u click on finalize or something and then its says connect to ac power if yes just get your battery charger and u get this thing that helps u see explore ur camera by also charging the battery at the same time just connect it to the camera and it wont say anything like ac power afterward.
Posted on Oct 15, 2008
SOURCE: camera not recognised by pc
I have found a solution download and run this fix from Microsoft. http://www.microsoft.com/downloads/details.aspx?FamilyID=c680a7b6-e8fa-45c4-a171-1b389cfacdad&DisplayLang=en
You have to log off then back on....this has worked for me my two cameras are now offering the transfer wizard once more.
Also see here....
http://www.velocityreviews.com/forums/t255653-hidden-windows-xp-photo-imagetransfer-wizard.html
If you have no joy with the Microsoft fix
Posted on Mar 07, 2009
  • 11967 Answers
SOURCE: my panasonic lumix dmc-fs3 will not connect to my
Start using a card reader instead of your camera.
Posted on Jan 13, 2010
I have canon camcorder fs30 - I ahve recorded a video to the memory card. I have downloaded Image Mixer 3 (and the version upgraded to 4.51). When I connect to USB the computer does not reconize the...
i would try to access the "memory card" separately. assuming you have an SD installed. this would mean you have an SD reader on your PC as well. if you have both, windows explorer will simply pop up when you insert the SD card. if you have neither, then you have to get the device recognized. first, verify your usb works. try a USB key or thumb drive with files on it to verify it can be used...aka driver installed. if good then camera should be readable. connect with known good USB cable....substitute this out to make sure. make sure camera is on and has power. make sure your camcorder is in play mode - briefcase with play arrow. good luck.
please note manual - page 72 - 85
http://gdlp01.c-wss.com/gds/4/0300003144/01/fs30-31-300-nim-en.pdf
Jun 13, 2011 | Computers & Internet
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
My computer is saying the software has been installed for the JVC GR-D73 but I can't access the files?
You need to download videos from your camera onto your PC. You need to install Image Mixer(included in your CD provided) and launch this program(camera connected either USB or FIREWIRE) and click which connection you are using and your camera must then be detected. If no response at all, update your driver. How? Right click MY COMPUTER, click MANAGE, then DEVICE MANAGER and look for yellow mark(e.g. GR-D73) if there is and update(you will be asked to insert CD) follow the prompt. Remember installing drivers on XP, Hardware must be connected first before doing so. Good Luck
Mar 11, 2010 | JVC GR-D53 Mini DV Digital Camcorder
I have a JVC Digital video camera model GR-DV500U I'm trying to connect to my computer with a dv cable. my computer handles the 6 pin but the 4 pin for the camcorder is to large for the connection. Can't...
I presume that you are using desk top computer, thus it has bigger connector. Solution, have find this connector so that one end fit to your cam and the other end fits to your PC. This connector have the same format(protocol) and easy to find in computer store. USB streaming is ok for this model for earlier windows OS, haven't try with windows 7 yet. hope it helps
Feb 26, 2010 | JVC Cybercam GR-DV500US Mini DV Digital...
Getting my pictures back onto my camara
Connect camera with computer with USB cord, power up camera, computer will recognize it and if you installed Sony image mixer software that will prompted, close it, click My Computer, click removable Disk, click folder to open it, now you can copy pictures from computer and paste here but be careful about picture file name should be DSCxxxxx some thing, if you have already changed file names then camera will not show these picture in playback mode though pictures would be on memory stick.
Apr 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera not communicating with computer
First of all; to all users.
You do not need to purchase any software at all.
If you run XP you might not need the usb driver for your camera either.
If you run Vista, then older cameras have a (USB) driver problem with the system.
If you run win 2000, ME, Win 98 then you do need the usb-driver and a simple imaging program.
There is a simple solution for all cameras which have connection problems.
Buy a card reader (they are cheap), connect via usb, install the driver if required, insert the memo disk from your camera - and that is it -.
The best free imaging program is PICASA3 from Google.
You can create Albums, manipulate images, import and export plus many other things for non professionals.
Jan 24, 2009 | Fuji FinePix F650 Digital Camera
Help please
1. plug usb into PC
2. plug usb into camera
3. turn camera on
Windows should report that it is detecting a device. If it doesn't then it may be because the camera's hard drive IS the device it would supposed to be detecting, nes pas?
Dec 05, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Problem with hearing sound when I connect Sonytrv33e camcorder to my computer with USB
Make sure that the sound capture device setting is on USB audio.  In image mixer - click on the USB icon onthe left of the screen and then click on the wrench icon in the upper right corner of the screen.  That will bring up another window.   In this window check to be sure that the sound capture device setting is USB audio.
Mar 10, 2007 | Sony Handycam DCR-TRV33 Mini DV Digital...
Downloading problem
You need to give me the version of Image Mixer you have installed. Basically what you need to do is to connect the camera via the USB to the computer and then follow the instructions. Daniel
Sep 14, 2005 | Sony Handycam DCR-TRV33 Mini DV Digital...
Download images
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the USB selection screen. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. To edit and manage images with a computer, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the provided USB cable.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Panasonic SDR-H18 USB Hard Drive Logo
61 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
