Question about Mintek DTV-263 26 in. TV/DVD Combo
TV dont respond
Neigther the tv manually nor the remote are working and the tv is stuck on the dvd mode. What can i do?
  • 1 more comment
  • Anonymous Jan 25, 2008
    I have a Mintel 37" flat screen that does not respond to the remote control ar manual buttons. It is also stuck in the dvd mode. It does cut on and of either manually or with the remote control. HELP--- can't find anyone to service this LCD.
  • JUDYO1 Mar 31, 2008
  • jennyd8 Apr 28, 2008
    My TV/DVD combo is stuck in the DVD mode. I cannot get any of the buttons on the TV to work or to switch over to watch the TV. I can play and watch a DVD though. That part works. Any solutions or local repair??
    Problem Solver:
  • 14 Answers
Here is the fix for that problem. I tried it and it works as I had the same problem. I used the COMPOSITE cable to make the splice rather than the COMPONENT cable since it is lighter and easier to work with and solder.
Posted on Mar 20, 2008
Tv stuck in dvd mode
There should be an input button on the tv to allow you to switch between dvd, tv and any other device you have connected.
Aug 22, 2014 | Akai LCT3201TD 32 in. LCD Television
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86:
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in:
May 05, 2011 | Toshiba 46VX700U LCD TV
Brand new dmr-ez49veb,has worked ok on setting it is now stuck in vhs mode and will not respond using remote to select tv mode.I have scart and hdmi connections to tv and have tv input selected to...
i have a panasonic dvd rcorder / video combi model DMR-EZ49VEB. I have recorded something on DVD, which is 4 hours in duration, and I want to edit the recording and split it into parts. I follow the manual, but when I press EDIT the option to split isnt even there? I am confused, it is SUCH a difficult manual to deciphre, but the only 2 options there are "Edit title name" and "Change Thumbnail". The others are not listed. the disc is not copy protected or locked and is of sufficient duration to split the contents. HELP PLEASE :(
Dec 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd stuck in conia clcd1930
To Eject the DVD, my conia clcd1930 needs to be in "DVD" mode. This Mode appears to activate power to the entire DVD module. So the Eject button will only work in this mode.
Feb 19, 2009 | Televison & Video
Toshiba 14DLV75, stuck in game mode, buttons on TV & remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Sep 03, 2017 | Toshiba 14DLV75 14 in. TV/DVD Combo
TV dont respond
Hello psp007,
I hate to be the one who tells you this, but you have one of those TV sets that are controlled by a single processor (as most combos have even LCD combos) and that processor may have gone bad. This is why you have so many problems at one time. I would suspect the the main processor board has a problem. You may want to take this to a TV repair shop, because there is so little you can do for this problem since if it is the main processor you will need equipment to troubleshoot this problem and to remove and install the component with the problem. Taking it to a shop is your best bet.
I hope this helps,
Thank you,
Mar 03, 2008 | Televison & Video
Sharp VT-51DV30 ....combo tv/vcr/dvd
unplug the unit and plug it back in see if it resets
Dec 02, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Mintek DTV-263 26 in. TV/DVD Combo Logo
152 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
