Question about Emerson MW8102SS 1100 Watts Microwave Oven
I need a turn table for this model - Emerson MW8102SS 1100 Watts Microwave Oven
  • 11,896 Answers
You can get one at partselect.com
or repairclinic.com
Posted on Dec 10, 2009
Do you have a glass turning table for daewoo microwave oven of the attached model in the photo
Just one recommendation. When it come to microwave, sometimes the glass turning table could be compatible with other brands. So I recommend that you edit this post and add a picture of the glass table that you want. That way you may have a better chance on getting help.
Jun 08, 2016 | Daewoo Microwave Ovens
Fix a kenmore microwave turn table model 721.80012401will not turn
http://www.ebay.co.uk/sch/i.html?_odkw=kenmore+microwave&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xkenmore+microwave+motor&_nkw=kenmore+microwave+motor&_sacat=0
Aug 11, 2014 | Kenmore Microwave Ovens
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
The glass turn table wont spin??
Hi, Your problem lies with one or both areas. If you remove the glass turn table, you'll see a plastic grooved driver that goes thru the floor. See if you can lift up and remove it. Does it look broken? If not, there is a drive motor underneath that drives this plastic piece which turns the turntable. You'll need the model number to take to your local parts house for replacements. Hope this helps.
Jan 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace the coupler that turns the table
If yo are referring to the turn table MOTOR, the following link explains how to access and replace:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. Since you did not include your MODEL NUMBER, I do not know how much yours would be. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can purchase replacement parts at the any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your model number and let me know. I hope this helps you.
NOTE: If you are referring to the turn table coupler, this is the small plastic shaft that connects to the turn table motor. This is the visible piece inside the oven where the glass tray sits. The coupler will simply pull straight up and come off the motor shaft. It can also be replaced if required. However, if the coupler were bad, the motor would still run. This would cause the glass tray to slip while turning.
Jan 20, 2010 | Microwave Ovens
Mod # JVM1653WO001 turn table not turning
On some microwave oven models there is a switch on the front panel that enables the user to turn the turn table on or off. If you do not see this feature on your front panel display, you probably have a problem with the motor that drives the carousel. This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
I believe your model number is actually "JVM1653WD001". This is the closest number I could find that compres to the number you provided. You can usually purchase replacement parts at the any of the following websites:
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If the model number is correct, the part number for a replacement is WB26X10038. You may also consider replacing the turn table shaft. This is what connects to the turntable motor and the carousel plate rests on. The part number is WB06X10138. If you have any questions, please let me know. I hope this helps you.
Jan 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven model #JVm1850wd002 turn table does not operate or
Take off the case. You'll see two prongs on the door. If they are out of adjustment.And don't trip the contacts. nothing will work. Theres nothing mech on the turntable, the micowaves make it turn. Just make sure it turns freely,and is clean.
Dec 29, 2008 | GE Microwave Ovens
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
56 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
