Question about Dell Inkjet 720 Printer
HOW DOES THIS THING GET POWER? I TRIED A USB CABLE AND NOTHING. I CAN'T SEEM TO FIND ANYWHERE FOR ANY ELECTRICITY TO BE PLUGGED IN EITHER.
    Genius:
  • 1,018 Answers
On the back of the printer you will see a rectangular slot for the power adapter (nicknamed: Brick) to plug into.
If you do not have the adapter, then you must get one. They can be ordered through any Dell authorized service deal or through Dell online.
Here is the link to the Dell website for the owners manual in PDF format.
Don
http://support.dell.com/support/edocs/systems/PRN720/en/OM/720_English.pdf
Posted on Dec 10, 2009
My tablet is showing the usb symbol on the screen and will not go anywhere cannot power down or anything tried plugging to my laptop and now to the electrical plug still nothing .
Mine did the same thing, son told me to hold the power, home button and volume up button for about 10 second and it would reboot, which worked for me.
Aug 25, 2011 | HP Tablets & eReaders
Computer does not recognize my external drive.
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Mar 14, 2010 | LaCie (300770) 250 GB Hard Drive
My n70 is not recognized when I plug in my USB cable. I am trying to download photos from my nokia N70 using a USB cable and its like its not plugged in to my laptop, nothing comes up when usually it...
there is a possibility that the cable is damaged or the phone port is damaged slightly in the data port. I was going to tell you to download drivers but it seems that it was working before so its either 3 things, computer, cable or phone. 92% of the time its the cable, just try another one. Please let me know if this works for you.
Oct 17, 2009 | HP Compaq Presario v3000z Notebook
I had a paper jam this morning, cleared the paper jam, and now the printer will not power up. I tried to remove the usb cable, and the power cable, reboot the computer, and replug in the usb and power...
First, Make sure that the printer is properly plugged in to a working electrical outlet and that it is hooked up to the computer as indicated. There should be two separate cables running out of your Dell 924, a power cord and a USB cable that communicates with the computer. If both of these aren't plugged in, then the machine will not function properly.
If the lights on your printer aren't working then it means one of two different things:
  • Printer has an internal electrical problem and needs repair or
  • Printer isn't receiving power from the outlet or power cord
Check whether, are you getting power from the socket by connecting some other component..If it works check whether the Power cord is propwerly connected, try pressing the power cord once..
If not the circuit may be damaged, Which cant be repaired inhome, you have to return to DELL service center and make it repaired
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 09, 2009 | Dell Photo 964 All-In-One InkJet Printer
My Western Digital 1TB hard drives do not power up when plugged into the USB Ports. No Blue light no nothing. I am however using the same power cable. I have changed the USB cable.
Seems like your case power is broken, check your warranty or buy a new one. to get your data back, open the case and unplug your harddriver, plug your driver in a PC computer and remove your important data.
You could also test a new power cable because it seems like your case doesent get any.
Aug 17, 2009 | Western Digital MyBook Studio 1 TB USB...
Nothing Happens
This happens when the GPS unit is completely discharged. Try charging the GPS unit from an external source (USB from your PC or 5V USB power adopter). After a full charge, if the GPS unit powers on then something is wrong with the power cable or the 12V plug and you need to replace it.
Aug 07, 2009 | Garmin nuvi 200 Car GPS Receiver
Static electricity damaged my t.v.
I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
Mar 12, 2008 | Olevia LT37HVS 37 in. LCD HDTV
My printer just wouldn't turn on
Good troubleshooting. Disconnect your printer from the PC and try the following:
Go to "Control Panel" -> "System" and click "Device/Hardware Manager". Check that "Show Hidden Devices" is checked inside "Options" and delete the USB ports it has listed, restart windows to have it re-install them and connect your printer. does it show any life signs?
Oct 15, 2007 | HP PSC 1610 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
