Question about HP OfficeJet R40xi InkJet Printer
Replacing carriage belt on HP R40xi. I purchased a new carriage belt for a R40xi printer from Precision Roller, but the instructions were for a HP 722c which is totally different from the R40xi. So far I have removed the top lid, two T-10 torax screws, rear access door, and the panel above the rear access door.
  • nwitt Dec 10, 2009
    His solution is to have some expert do it!!!
    President:
  • 2,306 Answers
The right and left front panels come off by pulling the inside edge outward, the shell above the print engine lifts off after removing all black torx screws and 2 silver torx screws in the back. This gives you access to the carriage assembly which will lift after the encoder strip is removed, by removing a screw on each end of the carriage shaft. The carriage belt locks in the carrier assembly by wrapping around a post. Best of luck to you in this ambitious endeavor!
Posted on Dec 11, 2009
  • 3,741 Answers
Replacing the old band and inserting the new band is just a one minute job.there are two mini white color or black color gears.one on left side and one on right side.on which the lining side of band has to be seated and exactly on the back side of the carriage there is a socket from where you have to pass the band .it actually hold the band tight there.its not difficult.but the difficult thing is to disassemble the printer.actually you have disassemble the complete printer to fit the carriage rubber band.as the carriage has to come out completely to do this.its very hard to reassemble if by chance you disassemble.its fitted on screws and hidden plastic locks inside the back side of the front plastic.you will require a normal screw driver and thin/strong knife.you will have to move the knife in between the sides where the knife gets blocked there will be lock.so then you have yo press that lock from knife and pull that side plastic bit up.there will be several locks.if any of the lock breaks that side plastic will not fit while reassembling.
so its advisable to get it done by a professional repair person familiar with this brand /model printer.as it will be safe and secure.
as there is no specific service manual provided by hp company.but the procedure is as follows
1)first the upper scanner assembly whole comes out.do not pull the assembly as the scanner cables needs to be removed before lifting the assembly.
2)then the sides comes out.the plastic sides.which are fitted with screws and locks.
3)then you reach the inner side.then a spring on the sides come out ,its very risky here,then the steel rod on which carriage moves comes out .
4)then the carriage comes out.
it requires lot of patience and concentration.if any mistake whole printer gets misaligned.
the cost by the technician outside should not be very much as the cost of the part broken is not very much.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Dec 10, 2009
How do i change sleve of hp 2300dn ?
the sleeve you are referring to is the Teflon sleeve located in the fuser unit and is covers the upper heating element in the fuser unit.. unless you are familiar with fuser rebuilds don't attempt it.. you can purchase rebuilt fuser units or brand new OEM units From Precision Roller Part number is RM1-0354-050,or RM1-0354-000
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Apr 24, 2014 | HP LaserJet Office Equipment & Supplies
Remove transfer roller 4650
Just curious as to what prompts you to think it needs to be removed?
It is part of that transfer belt assembly that is on the inside of the front door that opens out and down ( hinged at the bottom).
I have only seen the entire assembly for sale.
Easy as pie to change if you feel the need but the machine should tell you when to change it.
go to youtube and search for precision roller , then HP 4600 trnafer belt.
They have a video showing how to remove it and replace it.
Ray Charles could do it.
They also sell the assembly.
Rich
Mar 14, 2012 | HP Color LaserJet 4650DTN Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
HP 2610 need instructions to replace carrage belt.Need detailed instruction to determine if I am capable of doing this.
While I don't doubt your capabilities, replacing the carriage belt does require more than just take off the old one and replace with the new one. The unit needs to be re-calibrated and belt tension must be precise to ensure correct printing results.
If you want to try, look on this site for a service manual (if one is available) for the step by step instructions:
http://www.feedroller.com/Store/service_manuals.php
Jan 04, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hp desinejet ploter belt
Follow the procedure for replacing the carriage in the service manual.
he manual can be downloaded here: www.lpscomputer.com/ec/manuals.htm
The repair parts and repair kits can be purchased here: http://www.lpscomputer.com/c-637-designjet-250c-330-350c.aspx
Jun 04, 2009 | HP DesignJet 350c InkJet Printer
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet R40 only prints in pink
I had 3 bad printing cartridges. I went to Staples bought a new 23 and everything is printing fine now.
Feb 29, 2008 | HP OfficeJet r40 InkJet Printer
HP OfficeJet R40xi InkJet Printer Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
