Question about RCA HD52W59 HDTV Projection Television
Picture on our RCA model#HD52W59
The picture on our HD52W59 model is bent often upon turning set on, fixes self if you tuen it on and off several times . What causes it and can it be fixed resonable?
    President:
  • RCA Master
  • 1,779 Answers
This is probably cold solder joints on the IFT. It's an easy fix for a tech. Take care of it now so major problems don't incur.
Posted on Dec 11, 2009
My RCA HD52W59 problem
set is prone to two problems: high voltage splitter at front of set behind speaker grill arcs-------also set does have parts on HV board that do the same thing---HV transformer feeds voltage to the splitter.
Jun 07, 2012 | RCA HD52W59 HDTV Projection Television
How to fix my RCA HD52W59
These are tough sets with this problem.
Most sets for Convergence use a single fairly simple circuit but this one parts are spread across 3 boards--not conventional in any sense.
The parts are also special---RCA only---This problem in these is so extensive all you have to do is GOOGLE the model number with "convergence" to see how common it is.
These sets were so poorly made, parts and technical support does not exist that many shops (including the one I work for) resist or even refuse to fix them.
Mar 25, 2012 | RCA HD52W59 HDTV Projection Television
Have rca hd52w59 that has mind of its own. Turns volume down but not up. Turns TV on but not off. Flashes menu screen on and off. Screen formats changes, etc etc. Is the TV shot or is there a relative easy...
Thats a very common problem with that model which is caused by the small signal board needing replacement. Several version of small signal boards were used in that chassis but the people at www.tvrepairworld.com have replacement signal boards and will help you determine which version you require for your specific version if your not sure.
Jan 04, 2012 | RCA HD52W59 HDTV Projection Television
My 52" RCA projection, model
comon fault is one of the picture projection tubes is broken.not worth fixing
Mar 29, 2011 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
RCA HDR52W87 picture is bent and color is fuzzy; what could be the problem
Is it bowed top and bottow? One fix and a common problem with this set is there is a fuse right next to the flyback the seems to open because of broken solder joints. There is 3 off them and the middle one seems to blow all the time. Check the fuse with a meter and see if its open. If it is, follow the next set of directions.
To fix this, you will need to resolder the flyback and several other components. Then jump the fuse or replace it. I have personally done both but I don't like to jump the fuse because it defeats its purpose as a fuse.
You will need a T-20 and a T-10 screw driver to take the back off. The flyback with be on the left hand side of the set with a red wire coming off the top of it and the fuses will be located an inch or so to the right of the flyback. If you have schematics, sorry I don't know the designations of the components.
Dec 02, 2009 | RCA HD52W59 HDTV Projection Television
Picture is bent. color is a bit fuzzy and 3 lines
Ur convergence it dead,know how to solder?Buy a convergence kit use what in that kit.Tries websites Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59, Convergence is out, not even on set up menu, and also the picture is bowing. how much to fix or just use it for target practice
you can fix it for 24.00. You can get the ITC222 & ITC222A convergence option missing repair kit at the following link which contains the parts and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | RCA HD52W59 HDTV Projection Television
42' rca problems
my tv did the same thing my power supply board had went out had to replace it now I have no problem did you notice a hiss when you cut it on if so it is the same problem
Apr 07, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
