Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung rear projection problem
My samsung rear projection tv has always worked reasonably well it is only 2.5 years old yet this morning while watching it switched off itself and now will not turn on. The red button on the front flashes as it does when it turns on usually but no picture on sound come on. I have tried unplugging, turning off at side of tv and wall all to no avail..please dont tell me its over as i have no warranty that i no of. any help appreciated.
Sounds like you may need a new lamp.about 150.00 to 200.00$
Posted on Jan 24, 2008
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
My Toshiba rear projection TV -43hx71 is periodically turning itself off and on while we are watching a program. What could this be?
When tv shuts down for some reason, does it turn on again itself or you need to press power button to turn it On?
Let me know how old is this tv and any other related info that you think might be helpful to diagnose problem.
Thanks.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
White spots
Bad news, The Light engine has gone bad.The cost of the light engine is usually over $800.
Do Not Repair. Cut your loses. Always buy an extended warranty on any new electronic gadget, especially a TV. It will pay for itself.
Jul 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
WE always need the model #..............................T.
Nov 15, 2007 | Pioneer PRO-99 TV
Samsung HLP6163wx
when is the last time you changed the lamp ?  are the fans clean
Oct 15, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
