Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
HP Media Center
it seems that USB ports are not responding?
    Sergeant:
  • 239 Answers
Check in your device manager and look at your usb drivers and make sure there is no yellow question marks by any Usb devices and also make sure its not disabled, See if you can do and update also but make sure you are an line before you update it. Hope your usb start working for you after that
Posted on Jan 20, 2008
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
Hot sinc
Dear NWH1
there is convertor available , which converts USB to serial , your need to connect that cable on USB and attach our serial to usb connector to it,
It will work
Thanks
Gizmo
Dec 24, 2007 | Computers & Internet
I have an HP Media Center PC m7330n. It recently was infected with a host of viruses and rootkits. I eliminated all the viruses and rootkits with a battery of anti-virus programs. Everything works as...
You might want to try to go to the device manager and go to the Universal Serial Bus controllers
Try to uninstall everything and restart the computer.
See if that will let the computer recognise the USB ports.
If that does not work, you might want to reinstall the chipset drivers of your motherboard.
Hope this works for you.
Jun 21, 2011 | HP Pavilion Media Center TV m7330n...
Mouse 6 pin ps/2 port on back of HP Pavilion Media Center TV m7680n not working it is enabled in bios where can i buy one online i need mouse and keyboard ps/2 ports to go ...
You are using the correct terminology.
Ps2 mice are far and few between. Use a USB mouse, likewise keyboard and add a USB to PS2 adapter.
Mar 21, 2011 | HP Computers & Internet
Usb ports not working
buy a new mother board or use recovery media after saving files and clean out usb ports
Jun 13, 2009 | HP Pavilion dv9000z Notebook
The Media reader is not reading any cards but the indicator light comes on when I insert the cards
Try plugging your media reader into another USB port. If it is plugged into a USB hub, then that is your problem, plug it directly into your computer. Although you should be able to daisy chain USB devices, in actuallity that does not seem to be the case. I have found a lot of devices do not like USB hubs. Also you may want to try another USB cable. These things get corrosion on the contacts and sometimes make poor connections when plugged into the computer and/or devices.
Jun 08, 2009 | HP Compaq Presario Media Center SR1750NX...
Samsung CLX-3160FN won't print from my HP Pavilion Media Center M7467C
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
May 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Misfeeds and partial printing with CX8400 on Vista Machine
Make sure you are connected to a USB 2.0 port on your computer. The printer does not do so well on a USB 1.1 port.
If you have a desktop, you can add a USB 2.0 adapter card. If you have a notebook you can use a USB 2.0 converter card (PCMCIA or PC Card or CardBus(32bit) or whatever).
Apr 11, 2008 | Epson CX8400 All-In-One InkJet Printer
HP DRIVERLESS USB FLOPPY DRIVE F5101B
Update your laptop chipset driver and check for broken usb ports.
Dec 11, 2007 | HP (F5101B) External Floppy Drive
Computers & Internet Logo
19 people viewed this question
Top Linare Computers & Internet Experts
gautam jha
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Iqbal Husain
Iqbal Husain
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
