Problem with Citrix GoToMeeting
INSTALL ERROR - THE INSTALLER COULD NOT LOCATE A SUITABLE FOLDER TO INSTALL INTO
Posted by avatar on Dec 10, 2009
Solutions (4)
Best Solution
Try this:
The issue seems to be related to a Windows Security Update. Our engineers are working on this.
Can I get you to ask your client to try the following:
After clicking the link to join your meeting.
Select the option to manually download the software and save the executable somewhere you can find it easily. Most people prefer to save the file to their desktop.
Next, right click on the icon and select “Run As…”
Finally, DESELECT the option to “Protect my computer from unauthorized program activity.”
And select OK.
You should be able to connect into the meeting.
You can also try joining the meeting through a different browser such as firefox.
  • By Author imagekonos44 Dec 10, 2009
See http://support.microsoft.com/kb/955759
Permanent fix Add registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags
REG_DWORD: {5042648C-F439-468D-859B-6CD12BA02D3A}
Value data: (hex) 0x00000001
  • By Author imageTJK915 Dec 11, 2009
FIXED !!! Citrix support said the problem was caused by windows update kb955759 that went out wed night. I uninstalled it from Add or Remove programs, rebooted, clicked on a GoToMeeting link in an IM, filled in name & email address and it worked!
If you've previously run GoToMeeting client, you won't be prompted to download the software again, so you have to use the Registry Method (Solution #2)
Suggested Solution (3)
Add registry key:
  • by Author image TJK915 Over a year ago
    • By avatardookies9598 Sep 21, 2010
    • not helpful if your not computer savvy
Source: cannot find suitable folder to install to
Was this solution helpful?
No
Yes
Uninstall MS Patch KB955759 until installer ist fixed
  • by Author image donadi Over a year ago
Source: the installer could not locate a suitable folder
No
Yes
Most of such type of problems occurs with respect to availability of secondary memory space in order to install
  • by Author image injkiran Over a year ago
Source: getting error message saying the installer could
No
Yes
Add Your Solution
See all Citrix GoToMeeting Problems
