Question about RCA RT2760 System
Extending Subwoofer Cable Connections
I have an idea of how to fix my problem, just want to make sure not to create another. I would like to extend the connections for the sub woofer so that I can move it more than 4 feet away from the receiver. Will extending cables cause any problem with the power source or distortion of the sound.
    Problem Solver:
I used a plug off of another surround sound spreaker had the same plug so i ran it into the regular plug and taped without cutting any wires works great on the other side of the room i ran myn like 20 ft away with no sound difference.
Posted on Mar 09, 2008
    Problem Solver:
  • 11 Answers
Souldn't if you use the same size or larger wire remeber the smaller the number the larger the wire
Posted on Jan 20, 2008
LG DR4810 black and white lines at top left and side of Picture extending accross middle of picture window. How Do I remove these?
I think you should take it back, cause! defective laser pickup, or the video processor, and possibly the audio/video cable, "replace to be sure"
May 08, 2012 | LG DR-4810 DVD Recorder
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
My Kodak Z885 shuts off when I try to use the zoom even after I changed the battery to a DuraCell Ultra CR-V3. Any idea why?
I experienced the same thing while i was fixing a problem with my lens not extending fully. I simply used a vacuum cleaner over the lens to remove possible dirt/sand. After my initial (lens) problem was solved, using the zoom would automatically shut off the camera, so i used the vacuum some more and all the dirt preventing the zoom from extending is gone, so the camera works 100%
Aug 05, 2010 | Kodak EasyShare Z885 Digital Camera
Black "tail" lines after every sentence and graphic on screen
same thing with my Envision 22" LCD. I tightened the VGA cable @ the CPU. All fixed.!! Check cable at both monitor and CPU. Replace cable. Check video card in motherboard. Try DVI cable if you have the connections. Good luck
Mar 01, 2010 | Dell E207WFP LCD Monitor
I have Vista on my laptop and I am getting the low disk space warning. When I click to fix it takes me to my recycle bin but, that is empty. If I want to delet some programs what ones are safew to...
so you may have 2 situations, a real low disk space or a hidden folders to be internet server.
You can uninstall all programs outside of windows op system, like games, music, movies, some demo software, old programs not used,...
Dec 29, 2009 | Gateway MX6030 Notebook
I have 15" subzero earthquake and i need to reconed
Usually the voice coil is bad on these subs...if your surround is rotted or torn - EXTENDING YOUR FINGERS PUSH DOWN GENTLY ON THE MIDDLE OF THE SUB AND RELEASE...Is it free? If not, forget the rebuild...If you need a kit for rebuilding the Earthquake...try Googling "Lesco Distibuting" in Orange City, FL and ask them who their closest Earthquake dealer is.
Good Luck
Jun 15, 2009 | Orion 15" Competition Subwoofer H2 15D4...
Extending subwoofer cable
The subwoofer signal is fairly hot, so you can go pretty far without significant signal degradation.
Use standard shieled audio cables and cable couplers to do this. I wold say you cold run it 50 feet without creating a problem.
May 06, 2009 | Audio Players & Recorders
Extending the power cable
Provided that your soldering skills are sufficient, you should be ok. Just be sure to observe the polarity (don't switch the wires around) and use an adequate sized wire.
Sep 03, 2008 | Sirius Sportster 5 Satellite Radio...
Power connection for L365 Fish finder
Fuses and Breakers
Attach the red or positive wire to a 5 amp circuit breaker. If the unit is connected directly to the boat’s battery, include a 2 amp in-line fuse. (In-line fuses are available at most marine supply stores.) The power cable includes a smaller "shield" wire. Connect this to a good ground.
Extending the Power Cable
If you need to extend the power wiring by more than 10 feet, use a larger wire size. This will allow the wires to deliver the correct voltage in spite of the longer wire distance. For runs of 20 to 35 feet, use #14 AWG cable. If you extend the power wiring, be sure all electrical connections are solid and durable. Soldering is the best way to make these connections. Insulate all connections using heat-shrink tubing or electrical tape. You may also use crimp connectors or a terminal strip, but be sure to use good-quality marine-grade parts.
Apr 15, 2008 | Computers & Internet
RCA RT2760 System Logo
171 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
