Question about Motorola Mobility Q9h Smartphone
My Motorola Q9h Smartphone locks up at the Windows Mobile Screen. Took battery out to do a hard shut down an nothing it just goes to the same screen and stays there. Anyone know a way to fix?
My motorola q9h cannot restart, when i press on button it just shows the motorola logo but cant open.
Remove the battery and hold down the power button for at least 30 seconds. This will reset the circuits. Put the battery back in and turn the phone back on. If it still hangs and doesn't load you may have a corrupt boot file. In this case you'll want to contact Motorola. Good luck!
Mar 03, 2011 | Motorola Mobility Q9h Smartphone
Hi I wan PC suite of this mobile. where can i down load it for free....
please,go to Motorola website and you will down load the pc suite for free.
Thanks.
Jun 22, 2010 | Motorola Mobility Q9h Smartphone
Can i change the os of my motorola q9h
I have a Motorola Q8 and only gives me the splash screen and nothing else, I can do?
Oct 29, 2009 | Motorola Mobility Q9h Smartphone
My motoq 9h is not booting up and the phone is stuck on windows mobile screen
Take out the battery for 2 minutes, then put it back in.
You are going to need to do a Master Reset which resets the phone to factory settings. This will erase all data entered into the phone, your contacts, calendar, etc., but will leave the SD card intact.
Hold down the center button of the navigational pad, and power button at the same time which will trigger the master reset. Follow the directions on the screen.
Once you've performed the master reset, goto the Motorola site to do a full update to your phone. This, in my experience, will eliminate the freezing problems associated with the Motorola Q9M, Q9c, Q9h, etc.
Good Luck!
Aug 02, 2009 | Motorola Mobility Q9m Smartphone
I have locked my motorola q and forgot the password
you will need to master reset the phone, this will lose all information on it, contacts everything, but after the reset it will stil be able to make calls etc, just all personal information will be deleted. Hold down center key and power button for several seconds and follow the on screen instruction, will be a creepy black and green coloration
Jun 16, 2009 | Motorola Mobility Q9h Smartphone
How to unlocked motorola Q9h
my mobile is moto q. i have lost my password
Apr 21, 2009 | Motorola Mobility Q9h Smartphone
I have a motorola q and it does not load up past the part that says windows mobile it stays stuck on that screen and wont load up how do i fix it
A hard resset should solve your problem
Sprint Moto Q
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
ATT
1. Turn the device off.
2. Press and hold the "E" and "Z" keys.
3. Press the Power button once.
4. When screen comes on, let go of "E" and "Z"
5. Press Power button once again.
6. Message that the phone has been reset.
7. Takes a few mins to reset.
Apr 20, 2009 | Motorola Mobility Q9h Smartphone
BSNL 3G INTERNET SETTING FOR MOTOROLA Q9H
Moto q9 phones don't havea the capability to use 3G internet yet. A software update will be released soon. Contact your service provider for details on when they will be releasing their update.
Mar 31, 2009 | Motorola Mobility Q9h Smartphone
Screen freezing on my moto q9h
You'll have to remove the battery. I had this similar problem with my Moto q9c. I ended up replacing the battery and haven't had the problem since.
Mar 24, 2009 | Motorola Mobility Q9m Smartphone
Motorola Q9m frozen how can I get my contacts
I can't tell you how many times this phone has frozen, and unless you've been using a sync program, you're out of luck.
You can do a hard reset, which resets the phone to factory settings by removing the battery to shut down, then put the battery back in. Hold down the middle key on the silver directional pad while powering on. It takes 5-10 seconds but you will see the "Master Reset" option on your screen, follow the directions.
This happened all the time until I went to the Motorola site and did full phone update ( http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp?country=USA&language=ENS ) Now my Q9m which used to freeze 1-2 times per month hasn't frozen in 6 months - good luck!
Oct 17, 2008 | Motorola Mobility Q9m Smartphone
Motorola Mobility Q9h Smartphone Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
