Question about Aprilaire 600 Humidifier
I have ice or water at the edge of my windows. I
I have ice or water at the edge of my windows. I keep adjusting the temp and the humidifier and nothing is working. When the sun is out the south side of the house windows clear up. When it becomes dark the moisture comes back. Terri
    Sergeant:
    Champion:
  • 232 Answers
You may need new windows, you should keep your house between 35 and 45% humidity but if your windows are condisating on the inside and that condinsation is freezing then either turn off the humidifier or get new windows
Posted on Dec 31, 2009
I have a carrier humidifier model BG49. When the furnace turns off due to reaching room temp. The water still continues to flow into the reservoir of the humidifier. Is this the correct operating...
Hello, The humidifier should turn on and off with the furnace's blower motor, If the humidifier keeps continously running than the solenoid valve is stuck open and should be replaced.
Jan 30, 2011 | Carrier LFP Humidifier
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Water not flowing into HE360A
If you used the plastic tubing to the humidifier(I recomend copper) there should have been a little brass tube with a flare on it. This goes in the plastic tubing to grip the the sleeve better. See if this helps
Tinner
Sunsetmech
Dec 14, 2009 | Honeywell HE360A1027 Whole House...
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Feb 10, 2009 | Aprilaire 700 Humidifier
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Humidifier not collecting water
To both, these sound like de-humidifiers. Is your goal to reduce humidity and dry your room?
If so, if the humidity is low, then the de-humidifier has no work to do. A cheap battery or dial humidistat will help.
If not, check for a clogged filter. No air moving spells no de-humidification.
Also check for a frozen evaporator coil. Same as above but this requires repairs.
Electric dehumidifiers are similar to refrigerators and window AC's. With the fan running, adjust the setting to a lower humidity setting until you hear the compressor kick in. If it does not even at the lowest setting, check the space relative humidity to make sure it has work to do. If it does, repairs may be as simple as cleaning electric contacts in controls or as bad as a refrigerant leak or compressor failure. If its bad, better to replace.
A humidifier adds moisture. If you have a humidifier and want to keep the static off your clothes and keep your nose from drying out, fill the tanks with water and add biocide.
Please do not view my comments as patronizing. Even seasoned engineers have difficulty grasping humidification.
Sep 03, 2008 | Humidifiers
Honeywell True Steam Humidifier
Yes you will want the out door sensor. The reason why is it is going to read the average temp outside and will adjust what you hum is producing due to the temp outside, that is so you dont cause condensation on your window. You can run it in manuel or auto but i would strongly reccomend to run it in auto.
Jul 02, 2008 | Honeywell Power Humidifier: Furnace...
Temp
My guess is that you are trying to bring the humidity up too high. There is a chart in the manual that suggests where to set the humidity at based on outdoor temps.
I try to keep the level at 30-35% in the winter.
Hope this helps.
Dec 02, 2007 | Kenmore 14410 Humidifier
Aprilaire 600 Humidifier Logo
166 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
