Question about Maytag Washing Machines
Maytag pavt244aww i have a maytag washer and the drum is moving around too freely. it jumps around while spinning with and with out clothes in it i have it disassembled and im looking for what stabilizes it or a part to replace it.
We had the same problem and it is a known problem by Maytag. They came and replaced the springs under the drum as the original ones were not stong enough.
Posted on Jan 11, 2010
SOURCE:
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Maytag washing machine gets out of balance
Could be broken suspesion leg or spring securing the drum
Sep 27, 2009 | Washing Machines
My maytag washer will not spin
HI, try to physically spin the drum.there should be some slight resistance but not a lot. if the drum spins freely and, with ease, replace the Motor control board. is has failed in this case.
***Now, if the drum dose not spin freely, this will confirm a failed electric motor.
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer model PAVT244AWW will not agitate during wash cycl
When the machine drains etc the gearbox locks up and the whole unit drum box and all spins when washing the gearbox innerds move the otherway so to speak and this cuasees a washing action this sounds as if the input shaft may need replaceing but it is usually better to replace the gearbox depends on finances but to be sure get a technition in to check and quote you first this is not something you can do if you have not done it before
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Pav2300 top loader balance problem
bigmur, you need the snubber kit for this washer. There was a service flash out on this model, SF-26-756. The kit includes the snubber and 6 new springs. Condition was, excessive vibration during spin, basket leans to one side. Kit number, 12002357. Check with your retailer...this repair may be covered. Catriver..post back
Sep 25, 2006 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
334 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
