Question about Maytag LAT3600A Top Load Washer
Maytag LAT884BAW Washer TopLoad
Question regardig were to connect grey power cord on the timer and circuits?
  • 1 more comment
  • dixiechick91 Jan 20, 2008
    Model number LAT8840BAW...serial no ends in FS which I believe is Aug 92 for age of unit.
    It's working!!! Watching very carefully for a full cycle to go thru..Had a few sparks the first time I connected it. Scared the pants off me. This old girl is not used to someone like that. Hey, but a girl has got to do... what a has to be done. I live in a rural area and repair men don't like driving this far. Sear's gave me a date of 2/1. I really need to wash before that don't ya think :)) Thanks again
    Do you know where I can find a manual for my machine LAT8840BAW?? I found one for Maytag Dep 1994 thru 1997. The only difference I could see was the wiring on the LAT880 had two additional buttons than mine.
  • robert samples May 11, 2010
    whats the age of this unit and is that a valid model number
    President:
  • 1,314 Answers
I show the powe going to l1 on the timer and the neutral connects to 7 on the pressure switch let me know
Posted on Jan 20, 2008
  • robert samples Jan 20, 2008
    pop me an email at [email protected] ill send you a wiring diag as close to your unit as i can the model youn gave me is not in their data base
    you might try www.maytag.com but verify the model num and stay ayay from sears service lol
6ya staff
SOURCE:
Maytag centennial washer topload does not wash or rinse but spins. Any possible solution?
hi,
first check the belts look under the machine maytags used to have two belts. if theyre slipping then your going to have to figure out how to re tension them. hopefully its the agitator cams. your going to have to study how your agitator comes apart, inside the agitator are a set of one way cams, usually the cap comes off and the cams are down inside. if the agitator does nothing at all with the belts are present then transmission or computer or timer failure. Maytag Washer Agitators Replacement Parts Accessories PartSelect
Oct 01, 2018 | Maytag Washing Machines
Washer not getting any power but cord and outlet are good
Lid switch open circuit or needs adjusting, Thermal overload (Inside motor) open circuit, timer faulty, fuse blown (if fitted)
Nov 08, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
No screws in the front of my maytag topload washer. do I acess the timer from the rear
Yes you do remove the rear plate by removing the back screws remove the knob off the timer if there is a nut holding it to the frame loosen it but do not remove until you take the back cover off when replacing the timer remove one wire at a time to keep them in order. Please rate if helpful.
Aug 07, 2009 | Maytag Washing Machines
Topload maytag washer partially fills by its self overnight or even a day or two may pass.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Your washer has a defective water inlet valve.
The link below is courtesy of. www.repairclinic.com,
They also provide repair parts, disassembly diagams and procedures.
http://www.repairclinic.com/SSPartDetail.aspx?s=b4a11i868761&PartID=868761
This may not be the exact part for your washer.
You will need the complete model number from the product ID tag which is affixed to your washer, to obtain the correct part.
TIP:
If it is convenient, it is advisable to turn your washer faucets off when not in use, to prevent accidental flooding
Jul 17, 2009 | Maytag Washing Machines
Washer will not spin
Sounds like it could either be an electrical problem, with the signal from the timer control board getting to the gear box,,, or it could be the gearbox itself.
Mar 12, 2009 | Maytag 22 Cycles Topload washer, SAV365Z
Washer and dryer won't run the washer will only fill
Hope this may help;
DON'T FORGET TO RATE:
Regards,
VOTIT
Sep 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag washer model mav5057awq
could be a bad timer. there is a switch there that would initiate the sequence.
Feb 17, 2008 | Maytag Neptune Washer
Maytag LAT9235AAE fills with water....
Pt, as long as you verified the lid switch is good, do this simple test. Get a piece of hose the same size as the one going to the pressure switch, connect it and blow into it. See if it starts agitating. If it does, there's your problem..Catriver post back.
Sep 27, 2006 | Maytag 22 Cycles Topload washer, SAV365Z
Maytag LAT3600A Top Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
