Question about Dell Inspiron 600m 1.6GHz Pentium M Notebook (162891033) PC Notebook
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
    Novelist:
  • 225 Answers
When you turn on the laptop keep tapping on F2 on Dell screen to boot in Setup Utility, then load to default settings, save the settings then exit. If still having same problem, connect to the internet download the latest BIOS from the support.dell.com after downloading then flash the BIOS. Laptop will automatically restarts then update the BIOS. Check if the press F1 prompt will still occurs.
Posted on Dec 10, 2009
Testimonial: "Awesome I just hit the setup menu and reloaded to factory settings!!!! Thanks a million"
  • 3,940 Answers
Generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
How do I go to BIOS?
You can enter BIOS setup or UEFI firmware via traditional method: Boot the PC, while the firmware starts to run, press F2/F1(Fn+F1 or Fn+F2). However, computer boots fast, maybe you often miss the trick to press F2/F1(Fn+F1 or Fn+F2). You can enter UEFI firmware from windows 8 or 8.1.
Nov 02, 2016 | Computers & Internet
How to Insert Boot Media?
Mostly you wil have to adjust the BIOS of the computer to boot from USB or DVD media.
When booting most computers mention the button(s) to press to get into BIOS:
--A Function key (such as F1, F2, or F3)
--The Esc key
--The Delete key
On some PCs, entering the BIOS may require pressing another key or a combination of keys. Keep your eyes open for an on-screen message that says something like: --'Press F1 to enter setup'
--'BIOS settings: Esc'
--'Setup = Del'
--'System configuration: F2'
If you don't catch it the first time, simply try again. Your computer's documentation may also tell you which key to press.
3. When you know the right key, start the computer again and press the key when the first screen pops up: You may hear a confirmation beep or see a new message. If you timed it correctly, you'll be in the BIOS within a few seconds.
Good luck,
A.Misset
Oct 18, 2016 | Computers & Internet
Will only run on safe mode
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
F10
Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate
load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Jul 08, 2013 | Compaq Evo D500 PC Desktop
My desktop 4210 is in paused mode how do i fix it
Step 1:
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc) Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 12, 2013 | Computers & Internet
Compaq stuck in utility mode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Feb 14, 2013 | Compaq Armada 1750 Notebook
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
I am stuck in the boot up process with the option
Look at the HDD (Hard Disk Drive) LED light...
Is it a steady red? Put your ear to the computer case. Do you hear a repeating clicking sound?
You should be able to press [F10] to get out of the BIOS Setup. If not, it may be a loose hard drive cable (open up the PC) or a failing Hard drive (replace).
Oct 20, 2009 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
How to enter bios
Hi...
To enter bios it so easy. When you turn on your computer you just only press delete to enter bios. If the bios does not exist you can press also F2.
Regards
PCmania
Aug 10, 2009 | ASUS Computers & Internet
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Computers & Internet Logo
570 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
