Question about Raymarine RL80CRC Plus GPS Receiver
My RL80 will not get past the power-on screen
My RL80 shows the power-on screen when started, but it then beeps, clears and then displays the screen again. It won't do anything except this, over and over. Any ideas?
RL80 can't boot one short beep?
Sometimes a memory module will go falty. Try taking one out and seeing if it runs. Then try it with the other one and see if it runs. If it runs with one and not the other then you have a faulty memory module. Also if you have any PCI cards that you can remove, it might work with them removed.
Dec 03, 2014 | Acer REVO RL80-UR318 - Core i3 2377M 1.5...
How do i reset the sid display in 2008saab93turbo after replacing battery
pressing the CLEAR button for 8 seconds. on older 9-5 and 9-3 SID's, that you must press CLEAR once & release, then press CLEAR a second time, and hold for 8 seconds. While holding down CLEAR for this second time period, at the 4 second mark "CLEARED" will be displayed, and you will hear 1 beep. If you release the CLEAR button at this point, the DTE and MPG will be cleared out. If you continue holding the CLEAR button past the 4 and 8 second marks, you will hear a 2nd beep, and "SERVICE" will be displayed. This now means that you have cleared and reset the Time For Service message.
Dec 01, 2014 | 2008 Saab 9-3
Dell e178wfpc monitor shows power on light but no display.
You should check if the vga cable is tightly connected from monitor to cpu. If the cable is connected properly,then the problem must be with your monitor. Check with any other monitor. If you hear a beep beep sound, when you start the computer then your RAM has been damaged or not properly connected.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
How to clear memory on a microlife bp 3ar1-3p
With power on, showing only clock.
Press M button, then press Power button together.
About 10 seconds, it'll display CL on screen.
Lift up your finger, CL will flashing.
Then press M button once, you'll hear 3 beep
Done.
Jul 08, 2012 | Microlife 3MQ1 Blood Pressure Monitor
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Somehow our Kenmore Elte Microwave Model 721.66469500 got locked. It says CHILD on the screen. Our manual says it should say "locked" I did what they said, push start and hold for at least...
In general, unlocking a microwave is usually one of the following:
1. Push and hold 'start' until it beeps or display changes
2. Push and hold 'clear/cancel' until it beeps or display changes
3. Push 'start' several times until it beeps or display changes
4. Push 'clear/cancel' several times until it beeps or display changes
5. Push and hold 'child/lock' until it beeps or display changes
If all these suggestions fail, try unplugging the oven for ten minutes and trying again.
Jan 19, 2011 | Vacuums
I have a toshiba estudio 200l wuth perform preventive maintenance on display. How do I clear off of screen?
turn off power
hold down 0 & 8 keys
turn power on with keys still held down till beep is heard
enter 252 then press start key
enter 0
press enter icon on display
power off & on
should clear service message
Feb 15, 2010 | Toshiba Office Equipment & Supplies
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Raymarine RL80CRC Plus GPS Receiver Logo
69 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
