Question about Kodak EasyShare DX7630 Digital Camera
THE LEN IS STUCK ON EXTENDED POSITION AND WILL NOT RETRACT TO THE OFF POSITION? BATTERY WAS FULLY CHARGE.
    Genius:
  • Kodak Master
  • 1,099 Answers
If no power on the camera:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
If there is power on the camera, bnut the lens is stuck:
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 10, 2009
2011 Honda Ridgeline center console cup holder can't retract. Stuck in the extended position. Won't close. Hits something.
Most often it is just gummed up with soda syrup. spray a little armor all into the mechanism and let it sit for a few minutes, then operate the mechanism. repeat until it works smoothly again, making sure to wipe any excess fluid up. Hope this helps.
Nov 11, 2015 | Honda Cars & Trucks
When stopping my 2003 s60 volvo the brake pedal gets really hard and car will not stop
Your brake caliper cylinders are fully extended and can't retract. You are going to have to disassemble your brakes and replace your disks because the only way the calipers can get stuck in an extended position is if the disks are worn enough to allow that to happen.. Time for a brake job my friend.
Feb 15, 2015 | 2003 Volvo S60
How do you fix a stuck lens that will not retract when camera is turned off?
Hello, Remove batteries from camera, try pushing the lens back GENTLY with the palm of your hand, Notice I said "GENTLY" or you will cause more damage than good. If this won't work than take it for service / repair.
Best Regards, Russell
Jan 25, 2013 | GE X500 Digital Camera
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
Len extended will not retract and the green led on the back tilt whe I keep press the power button
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2010 | Insignia NSDSC10A Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Lens will not fully close.Len get stuck when retracking.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2009 | Canon Cameras
The lens won't retract
If the lens is stuck out extended you may want to call Olympus Customer Service to discuss repair process and pricing. If the battery is fully charged and the lens still stays extended then this is a clear repair issue as something in the lens assembly has failed. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 30, 2008 | Olympus Stylus 710 Digital Camera
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
158 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
