Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
Blackberry 9000 speakerphone
Hi my bb 9000has the following issues 1)phone doesn't ring, 2) cannot hear speakerphone,
However, the media does work but when on hadn set - if you switch to speakerphone it stops working. Ear speaker works fine, microphone is fine, bluetooth works fine. I just can't hear the ringer or the speaker!
Hello, I have a blackberry 9000 and the volume when ppl call sounds low.
i'm not a blackberry person, but i'm sure just like other phones that it has the same settings. solution 1: while in call, press the volume up button on the side repeatedly until you can here. 2: go into menu, settings, there should be something like calls or volume or something similar, there should be a master volume, a media volume, alarm volume, in call volume and speakerfone volume, there may be others as well. select in call volume and increase to maximum. 3: your phone may just be a more quite phone, try a bluetooth earpiece or speakerphone
Aug 12, 2010 | RIM BlackBerry Bold 9000 Smartphone
My carrier won't get me the MEP code for my Blackberry bold 9000 in the cayman islands
you can get mep code by blackberry unlock codes provider at cheapest rate at 2-12 hours.
this website will help you a lot for unlock blackberry
Jun 11, 2010 | RIM BlackBerry Bold 9000 Smartphone
Callers cant hear me but i can hear them
Turn off your blackberry and take the battery out, place it back in and turn it back on.
If this fails to work then your mouthpiece is faulty, please contact a blackberry certified personnel within your area.
It would cost you below $20 to fix this.
Regards
Mar 07, 2010 | RIM BlackBerry Bold 9000 Smartphone
Can't hear unless on speakerphone
Your problem could hardware, need to install a small piece of audio that goes in the speaker. This is if you don't have the BB in mute.
Sep 02, 2009 | RIM Blackberry 8110 Cellular Phone
BB 8310- Speaker not working but headset and handset mode working
Install Blackberry desktop Manager ...Take Backup..
Reinstall the Software ....
if not happening contact service center as there might be any hardware problem.
Aug 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
Aug 04, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry sound not working
Same problem here with a BlackBerry 8830. Elsewhere found a solution for another model that worked for mine:
1) Plug in headset.
2) Turn off BB.
3) Remove phone battery.
4) Reinstall battery and let phone restart.
5) Remove headset.
Nov 29, 2008 | Cell Phones
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
193 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
