Question about Prestige 2 Button Remote Security System with Shock Sensor and Starter Disa
How can I disarm a prestige car alarm system without the remote? The owner cannot find the remote. The battery went dead and when we jump started it the alarm went off. If the drivers door is closed it will stop after about 8 seconds. If you open the door the alarm starts again and won't stop unless you shut the door.
    Problem Solver:
  • 7 Answers
Find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
Posted on Dec 15, 2009
  • Audiovox Master
  • 625 Answers
Turn the ignition on, press and release the programming button. This will disarm the alarm. If there is a toglle switch, flip it on then off.
Posted on Jul 21, 2011
  • Nelda Jul 05, 2013
    That didn't do anything.
    President:
  • 1,615 Answers
There is no way to do it at home
If it were that easy a theif would know how to do it also.
Your going to have to get a new remote programmed
Posted on Dec 10, 2009
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
Remote start only starts with key in the ignition
It sounds like the immobilizer bypass module has either lost its programming due to the dead battery or a voltage spike from jump starting/recharging the battery or it has malfunctioned. Without knowing which module is installed, it is not possible to determine if it can be reprogrammed. The immobilizer bypass module substitutes the transponder that is in your key and allows the vehicle to start. When it is malfunctioning, it may not be providing a signal or providing the wrong signal the vehicle ECU is expecting. The reason you can remote start the car with the key in the ignition is because the transponder is being read fromthe key and the ECU is allowing the vehicle to start.
Nov 22, 2011 | Prestige Remote Start
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
1996 Nissan Maxima - unlock car, anti theft alarm went off and car won't start. Got new battery, battery was dead, put in new battery, anti theft alarm still going off and car won't start. Please help
If the antitheft system is armed and isn't recognizing the key for starting, the dealer should be the next place it should be towed for reprogramming the key to the computer.
Oct 12, 2010 | 1996 Nissan Maxima
My battery died in my car i got a knew battery now my alarm is keeping it from starting
If the remote fails to disarm the alarm, manually disarm the system by turning the ignition on, then press and release the valet switch. You should hear two chirps, start the vehicle.
Sep 24, 2010 | APS20B Prestige Keyless Remote Alarm
I have a 02 silverodo battery went dead i charged battery reinstalled it it starts but dies and with the key out of the ignition security light stays on
you need to disarm the alarm. unplugging batt. or dead battery being jumped sets of the alarm not all alarms make noise
use remote to lockand then unlock doors need to be closed
or lock then unlock door with key if it dont reset then try passenger door
Mar 22, 2010 | 2002 Chevrolet Silverado 1500
This morning I came out to start my 96 jetta and the battery seemed dead. So I began the process of getting a jump and as soon as we connected the jumper cables to the jetta the alarm started going off. We...
The immobilizer feature was tripped when the alarm went off. It sounds like the battery was indeed dead. My Nissan 300ZX used to trip the alarm when I jump-started it, although my Audi A4 does not. When the alarm is going off, you have to disarm it with the key or key fob first, or you won't be able to start it. Try putting the key in the door, lock it, unlock it, lock it again, and unlock it again, just to make sure you get a couple of arm/disarm cycles, then try starting it.
Nov 12, 2009 | 1996 Volkswagen Jetta
Prestige 2 Button Remote Security System with Shock Sensor and Starter Disa Logo
1,709 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
