Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
Hi my bb 9000has the following issues 1)phone
Hi my bb 9000 has the following issues
1) phone doesn't ring in any profile; and
2) cannot hear speakerphone,
However, the media does work but when on the hand set setting - if you switch to speakerphone it stops working. Ear speaker works fine and microphone is fine. I just can't hear the ringer or the speaker!
I wan a know when i dial nomber from my bb handset y profile pic n name come of facebook user
That would only happen if you have your phone and your facebook account linked together. Facebook now likes to sync contacts with phone books. So that's most likely the issue there.
Sep 20, 2011 | RIM BlackBerry Bold 9000 Smartphone
My BlackBerry Bold will not ring or vibrate on incomong calls even after I pull the battery numerous times
Please, check all profiles if they are muted
Test the speaker to ensure it is functioning fine; not the ear piece ......... the back speaker. Try playing a tune or something.
Try a hard reset ......... pull the battery out while the BB is powered on. If that does not fix the issue, you may have to take it in for service; should be covered by your warranty.
Regards
Jul 13, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have a blackberry bold 9000 mobile phone , it doesn't ring when the back cover is on , but when i remove the back cover it rings fine , what seems to be the problem and can u suggest a solution , can...
Hi boy_great,
You need to set the settings for the cover and without cover mode of the blackberry ,
Please follow the below steps :-
  1. Find the advanced option in the profiles menu and change the in and out settings for the holster or the cover. I hope this is the problem in your case.
  2. I direct removal of the battery also works sometimes , all you need to do , is
    remove the battery when your phone is switched on and after thirty to forty seconds connect the battery back again and restart the phone.Hope his helps ..:)
May 11, 2011 | Computers & Internet
Hi how can i increase volume on my blackberry 9000. Even on high volume setting there is no ringtone sometimes
Hi there
On your Blackberry menu, there's an icon that resembles a person's head that represents profiles. In the profiles menu, you can select the volume for the notifications you receive when messages or calls come in. Choose "Loud" to hear all notifications at an equal volume, equivalent to the maximum output possible.
Some ring tones just remain less audible than others even when they're set to maximum volume. If you've tried increasing the volume of your notifications but still can't hear the ringer sometimes, try downloading a custom ringtone from the Blackberry App Store.
When selecting a custom ringtone, choose something distinctive and hard to ignore. When previewing the tone, determine whether it seems louder or easier to hear than your existing tone. Download more than one tone and experiment throughout the day.
After you've downloaded custom ringtones, set your phone to use these ringers by going into the applicable notification profile. Select "Show Tunes" and open the media folder where you've chosen to save your downloaded tones. Select the ringer you want and click "Set as Phone Tune."
Oct 04, 2010 | RIM BlackBerry Bold 9000 Smartphone
The volume is down when it rings and i cant hear it
On the right side there is a volume rocker you can use to adjust the volume. If that doesn't work you can change your profile settings
Go to the profile select menu, select Advanced and change the volume setting.
Jul 05, 2010 | RIM BlackBerry Bold 9000 Smartphone
CAN'T HEAR MY PHONE RING WHEN SOMEONE CALLS ME I HAVE TO PUT THE PROFILE ON VIBRATE
Each of your profiles can be set to different ring tones and different volumes, so whatever profile you have your phone set to, make sure you have it on a ring tone you can hear, and make sure the volume is turned up. Let me know if this doesn't work.
Jun 18, 2010 | RIM BlackBerry Bold 9000 Smartphone
My ringing volume is very low i have tried advanced profiles and put all setting on high however its still very low i can hardly hear it.
I have the same issue. It is a manufacturing fault. The fix with mine was to fold up a gum wrapper and place it over the camera flash, and re-fit the back cover. It may take some fiddling around as too much pressure will cause it to go low in volume again. another solution would be to place a dab of glue around the camera flash and let it dry before replacing the back cover. In the end, you just want to applie a slight pressure to the camera lens / flash area. Hope this helps
Oct 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Very low ring volume in blackberry bold 9000
I had the same problem. My ring was getting lower everyday. I've done my fair share of dropping the phone.
So, I read that other people were having the issue.
One genius, told us to take off the back plate, and just where the camera is, there is a greyish plastic plate riveted down with plastic knobs. You press on either side quite hard. If you can do this while the phone is ringing, you will hear the volume jump up and down. When it sounds just right, leave it alone, put back on the plate.
If it happens again, repeat.
You may need to buy the speaker plate after a while. It's only 10 bucks on cnn.cn
Oct 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Bold 9000 ring and alert volume way too low, regardless of settings
Some of the ringtones in the Bold don't seem to be suited for "loud" profiles.
Try to edit your settings for the ringtone, making sure you pay attention to the correct settings.
To edit your ring settings
-go to your "profiles" screen -roll the ball to the bottom and select "advanced" -highlight the profile you want to edit -use your BB button to select "edit"
-choose the "phone" application -choose the setting you would like to edit (in holster or out of holster) -choose your volume setting from here.
This should solve your problem
Apr 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
91 people viewed this question
Top AT&T Cell Phones Experts
Oloyede Monsuru
ismael castillo
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
