Question about Philips Pocket Memo 9360 Handheld Digital Transcriber / Recorder
We are trying to run the Pocket Memo software in Windows 7. However, it does not appear to loading properly.
  • 207 Answers
Philips pocket memo LFH 9730
Hello I don't recognize that model may be you try to say Philips Digital Pocket Memo LFH9370.
Your unit charges two ways via power supply direct on the portable or via docking station, make sure you have the proper rechargeable batteries you must have the LFH9154 if you don't have this batteries you can buy them on the next link http://www.tvps.com/Products/Philips-LFH9154-AAA-NiMH-Rechargeable-Batteries---New-9154__PH-LFH9154.aspx
May 06, 2014 | Philips Audio Players & Recorders
Tip
Troubleshooting 101
Fix common PC problems Having trouble with your computer? You've come to the right place. Even if you don't know a computer language (or want to), you can solve several common PC problems on your own.
F1 is magic: Get help on your PCtroubleshoot.jpgIf you can’t figure out how to complete a particular task in your software program—and you’re using a PC—the most important shortcut to know is the F1 key. Just push it while the program—Word, Excel, or whichever program you’re using—is open and active, wait a moment, and the Help window specific to your active program will appear. The F1 key works with almost all Microsoft products, so it’s a helpful starting point for a wide variety of problems.
In this article, we offer many ways to do what you need to do in Windows 7 and Windows Vista. Often, there may not be a Help topic for Windows XP, but the process is often the same as in Windows 7 or Windows Vista. The only difference is usually where to find the link in Control Panel. Most often, it’s just a matter of slightly different wording in the heading or the text describing the task. Don’t worry. If you search in Control Panel, you’ll usually find the link you need.
The basicsIf you’re encountering a different kind of obstacle – your new device won’t appear on your desktop, an application you added won’t run, or your computer is refusing to start up – here are a couple of preliminary steps:
  1. Before adding any major hardware or software to your system, make sure you've recently backed up your Windows 7-based PC or your Windows Vista-based PC as a safeguard. By using the automatic backup functions, you can schedule regular upkeep for maximum convenience.
  2. Write down the contact information for Microsoft Customer Service and Support, should you need to consult an expert. Take a second to print the below instructions as well, and keep them handy as you walk through the troubleshooting process.
  3. Many issues can be resolved by simply checking to be sure that all of your plugs are connected properly. After you are sure of that, try restarting (“rebooting”) your system. Turn your computer off, and then back on a few seconds later. If the problem continues, follow the steps below.
Locating the problem Ask yourself if the problem is related to hardware, software, or the operating system (such as Windows 7, Windows XP, or Windows Vista). The following are some common indicators that can help you decide which is the right answer.
If you're uncertain, don't worry. Just start at the top by determining if your software is working, using the Software errors section that follows. If the issue persists, proceed to the Hardware trouble section and then to the System failure section.
You can also find really helpful information at Microsoft Help and Support. If you'd like to search by individual program, try the Product Solution Center. Or check the columns and blogs found on the Windows Community Web site, where you can find helpful input from experts and fellow computer users.
The lists on the right side of this page may also help you narrow down the type of trouble you are experiencing.
Software errorsIf programs refuse to install, won't appear on your desktop, can't seem to run without freezing, don't load at a decent speed or function properly, or Internet access is unavailable, here's how to troubleshoot:
General issues
  1. Confirm that your PC meets the software's minimum system requirements. If it doesn't, you'll be unable to run the program without upgrading your computer's hardware. Note that PCs which barely meet or just slightly exceed these minimums may run the software more slowly and can be less reliable. Windows 7 and Windows Vista users can reference the Windows Experience Index to quickly gauge their PC's general capabilities.
  2. Check for compatibility with Windows 7 and Windows Vista.
  3. Close open programs and windows that you're not currently using. These can eat up system memory and processing power, slowing your PC or preventing additional software from running. Try running the program again.
  4. Check available hard drive space. Roughly 5 to 10 percent of your hard drive's total storage allotment should be left free to ensure optimum system performance in Windows 7 and Windows Vista, prevent crashes, and keep Windows running at top speed.
    Note Use Disk Cleanup to free more space:
    Windows 7
    Windows Vista
    Windows XP
    Check for program updates and information on frequently encountered issues at the software manufacturer's Web site. For Microsoft products, you can also load Windows Update for Windows 7, Windows Update for Windows Vista, or visit the Microsoft Download Center. If you install an update, restart your computer, and attempt to run the program again.
  5. Uninstall or delete unwanted programs in Windows 7 or Windows Vista to cut down on clutter and remove any drain on your system's resources.
  6. Disable programs you don't use to in Windows 7 or Windows Vista by preventing them from automatically loading when Windows starts. If you’re running Windows 7, restart your computer, and try the program again.
  7. Defragment your hard drive in Windows 7 or Windows Vista to improve performance.
  8. Scan for viruses and spyware. Windows Defender in Windows 7 and Windows Vista can help detect and prevent threats, along with preventing annoying pop-up notices and unauthorized home network intrusions. You can scan your PC for free.
  9. Reboot your computer and try loading the program again. If it still won't load or work correctly, you may need to uninstall the software and then reinstall it from scratch and reboot again. Advanced users can also try these advanced troubleshooting tricks in Windows 7 and Windows Vista.
  10. Consult Microsoft Help and Support and the Windows Community. If live assistance is required, first contact the software manufacturer's customer support department. For additional assistance, try Microsoft Customer Service and Support.
on Jan 17, 2010 | Computers & Internet
Hp ipaq pocket pc 2002 sync windows 7
is not outlook now dead?, MS buried it long ago?
(ever think there is HP driver needed?)
ask here at HP.
nobody uses, Ipaqs in USA< its 100% Obsolete now here.
fixya is not HP,
so...... when fiddling with relics, be best to as real HP folks no?
https://h30434.www3.hp.com/
Dec 19, 2017 | HP Computers & Internet
Cannot run philips LFH9398 pocket memo on my mac
the philips models are not MAC compatible. However, they normally show up as a folder and you can copy files.
Apr 29, 2011 | Philips Pocket Memo 9360 Handheld Digital...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
We have a aiptex pocket cinema T20 which will not connect to an acer 7551 which is running windows 7. No icon appears, please advise
You need to set up your video card to output and mirror your monitor to the projector. On Windows 7 hit the Windows Key + P and select duplicate.
Mar 14, 2011 | Aiptek T20 Pocket Cinema DLP Projector
My Dell Pocket DJ Sofware in not compatible with
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Feb 22, 2010 | Dell Pocket DJ MP3 Player
How to play ps2 games on pc
there is the software called pcsx2 software which allow to play ps2 cds on pc
Dec 18, 2007 | Computers & Internet
Philips Pocket Memo 9360 Handheld Digital Transcriber / Recorder Logo
138 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
